 SR86 "How to"First  < 2 3 4 5 6   Last
Chemtrails
78 posts [100%]
Nibiru. Ca
 Re: (will_drift_4_food) » Reply  Edit
LOL....I did read your post to fast. That way makes more sense now.
I Have a s14 swap and I have no notched X-member, No X-member spacers, Motor sits perfect. The motor is a really tight fit around Rack on Driver side Coulmn portion. But other than fits great. I did have to cut a lil bit of the under hood support.
Nice on the wiring diagram!
"If patience is a virtue, Then time is ment to hurt you".
knshro13
5 posts [100%]
montebello ca
Thanks for the diagram. i guess ill just go that route instead of using the existing relays. its much easier.
Ill do a write up after im done.
will_drift_4_food
561 posts [99%]
The ATL
 Re: (knshro13) » Reply  Edit
Way easier. That diagram, along with the FRSport writeup should get most engines running in a weekend.
Will_drift_4_food
1984 SR-5 Coupe - Now with SR20 power!
1987 Supra Turbo
Adam134
282 posts [96%]
Toronto Ontario
Did you run your waterlines? I just grabbed my SR20 yesterday and I'm working on thinning out the harness and I'll be dropping it in this week just wondering about waterlines..
will_drift_4_food
561 posts [99%]
The ATL
 Re: (Adam134) » Reply  Edit
For waterline info, look back one page (or http://forums.club4ag.com/zero...98209). All the fitting sizes are there, though the S14 (maybe) and S15 engines (as well as FWD variants) have different coolant lines than the S13. I also bought a Stance spacer that adds a 1/8" NPT port between the head and the driver side waterneck, but I'm not using it because it is impossible to tap it for the OEM Toyota sending unit. If you are using the factory turbo manifold and elbow, just buy the ISIS waterline kit from http://NissanParts.cc. Top and bottom mount kits available. If I read the HTML correctly, this link should show you both of them: http://www.nissanparts.cc/cata...3560
$140 seemed like a lot to pay for a waterline kit so I decided to make my own, but if you spend the money for the ISIS kit, I can almost guarantee that you will save time and (a lot) of money over doing it yourself. Of course, I ended up spending a little more because I had to guess at some of the angles for the fittings (mostly due to having a non-standard top mount setup), and ended up with several "extra" fittings. If you go by the sizes and angles I posted, you should only have to alter the lengths of the hoses to make it work, and even then they will be pretty close to the same lengths. I use PTFE fittings and hoses from http://frozenboost.com, as I haven't found them cheaper anywhere else. I've had pretty good luck with them (good prices/fast shipping), and they also sell couplers, clamps, and aluminum tubing for plumbing your intercooler setup.
The tricky one is the coolant return line from the turbocharger, as it is on the back of the motor and nearly impossible to access once the motor is in the car. My advice is to replace the rubber hose and attach the hose barb fitting and return line prior to installing the motor in the chassis. Also be careful not to damage the heater core nipples when dropping the motor in, or there will be another couple of hours work to remove the dash and plenum in order to replace the heater core (which appears to be impossible to find in the aftermarket). If I had it to do over again, I'd cut the 90deg bends off of the factory heater core inlet and outlets, and have some -6AN male fittings welded straight on to them. This would make the job of fitting heater hoses much easier also. <br /><br />
Modified by will_drift_4_food at 3:46 AM 4/2/2012
Will_drift_4_food
1987 Supra Turbo
Rey Trossi
637 posts [100%]
Bay Shore NY
Quick question on the power steering. Did the sr20 power steering pump bolt right up the ae86 rack ?
will_drift_4_food
561 posts [99%]
The ATL
 Re: (Rey Trossi) » Reply  Edit
I never had PS on my 4AG, and went with a manual rack conversion when doing this swap, so I can't answer definitively. I believe that this question was addressed earlier in the thread: http://forums.club4ag.com/zero...07188. Since no one mentions having to use custom PS lines, I'd say it probably all works.
Will_drift_4_food
1987 Supra Turbo
Rey Trossi
637 posts [100%]
Bay Shore NY
Thanks yeah I read it before I just wanted to make sure. I guess I will find out this weekend when I get to it.
Rey Trossi
637 posts [100%]
Bay Shore NY
I found a few stores that make custom hydraulic lines for any car aplication.
MarkD1037
58 posts [100%]
Greenville NC
When you use the subframe spacers do you need to extend the steering column, if so how would you do that. I have PW steering.
will_drift_4_food
561 posts [99%]
The ATL
 Re: (MarkD1037) » Reply  Edit
You do not need to extend anything unless you are converting to a manual rack.
Will_drift_4_food
1987 Supra Turbo
pandatrueno4ag
238 posts [100%]
Boise ID
Quote, originally posted by will_drift_4_food »
I do have power steering on mine and it bolted right up. I just used the stock AE86 lines and reservior. Just used the stock parts as well from the SR PS pump and rotated one part to fit better.
Also, I have a question for will_drift_4_food, how is it drifting with no power steering in your car? Also what size wheels are you running? I found it very hard to drift with no PS and 16x8 wheels. Power steering FTW!
goodknight
63 posts [100%]
Warren County NJ
Is anyone running air conditioning in their sr86s?
Anyone have input into what components you'll need?
Thanks.
2JZuL8R
5 posts [100%]
Reno NV
Can someone message me and help me with wiring my windshield wiper motor? It seems that on the 240 they have the plug on their body harness while the GTS AE86 has it on the engine harness? Totally stumped right now. Thanks.
» Return to Engine - Other Toyota engines and off brand powerplants.
