 T50 Transmission Rebuild Kit $275 picked up or $300 shipped [Archived]
BoRoYaSui
2033 posts [100%]
long beach ca
 T50 Transmission Rebuild Kit $275 picked up or $300 shipped Reply  Edit
thread moved.
Modified by BoRoYaSui at 2:24 PM 7/23/2010
bigt92604
1075 posts [99%]
 Re: T50 Transmission Rebuild Kit $275 picked up or $300 shipped (BoRoYaSui) » Reply  Edit
Did they ever make stronger syncros then stock?? Are these Toyota rebuild kits or another brand??
BoRoYaSui
2033 posts [100%]
long beach ca
 Re: T50 Transmission Rebuild Kit $275 picked up or $300 shipped (bigt92604) » Reply  Edit
No, the synchros are made out of a "softer" metal so that the synchro wears first and not the hub. Similar to a clutch and a flywheel. If you made a clutch out of the same material as the flywheel your engagement would be very harsh and the flywheel and clutch would wear at the same time.
These are aftermarket kits. However, the bearings are same as if you were to buy it from toyota. The paper gaskets and synchros are aftermarket.
apostolisp
2 posts [100%]
Athens Attiki
Hello, my name is Apostolis. I was wondering if you could send me only the 1st, 2nd and 3rd syncronizer rings. Also if possible the 1-2 shift collar. Thank you in advance for you time.
BoRoYaSui
2033 posts [100%]
long beach ca
 Re: T50 Transmission Rebuild Kit $275 picked up or $300 shipped (apostolisp) » Reply  Edit
I can sell you the syncros but as a set 1-5. The shift hub you can get from toyota. I could order it for you I think its around 120
BoRoYaSui
2033 posts [100%]
long beach ca
ttt
BoRoYaSui
2033 posts [100%]
long beach ca
ttt
apostolisp
2 posts [100%]
Athens Attiki
Hi, sorry for this late reply (some personal problems). could you check for the hub and tell me how much is going to cost me (the 1-5 syncrinizer rings and the hub) shipped to Greece. Thank you for your time. With regards Apostolis
BoRoYaSui
2033 posts [100%]
long beach ca
195 shipped for everything. If you want it please send me an email to boroyasui@yahoo.com
BoRoYaSui
2033 posts [100%]
long beach ca
bump
gen4lx
2 posts [100%]
Adelaide sa
Hey dude,
can you tell me what the outer diameter of the front (input shaft) bearing is and also roughly how much for postage if you are willing to ship it over to Australia.
Cheers,
Jason
BoRoYaSui
2033 posts [100%]
long beach ca
 Re: T50 Transmission Rebuild Kit $275 picked up or $300 shipped (gen4lx) » Reply  Edit
outside diameter is about 68mm. part number is nachi 30RT06S3N.
price for the kit is $325 shipped to you. please send me a pm or email to boroyasui@yahoo.com.
gen4lx
2 posts [100%]
Adelaide sa
Cheers Dude,
I'll go check out my box and confirm it's the correct one then PM you with further info.
Jason.
BoRoYaSui
2033 posts [100%]
long beach ca
ttt
BoRoYaSui
2033 posts [100%]
long beach ca
ttt
kouki paul
8 posts [100%]
emerald isle
can you get rebuild kits for k50 transmission?will you ship to ireland if so?thanks
Made square to go round! ;)
BoRoYaSui
2033 posts [100%]
long beach ca
 Re: (kouki paul) » Reply  Edit
yes. please send me an email. should be only an extra 25 dollars to ship internationally.
kouki paul
8 posts [100%]
emerald isle
email sent!
BoRoYaSui
2033 posts [100%]
long beach ca
sorry the k50 rebuild kit has been discontinued.
still got a few t50 kits left.
BoRoYaSui
2033 posts [100%]
long beach ca
ttt
BoRoYaSui
2033 posts [100%]
long beach ca
ttt
ToyTA22
1 posts [100%]
Tweed Heads South NSW
Hi. Would you have a set of five synchros and a gasket set available. If so how much including postage to Tweed Heads South. NSW. Australia Postcode 2486.
Thanks.
BoRoYaSui
2033 posts [100%]
long beach ca
 Re: T50 Transmission Rebuild Kit $275 picked up or $300 shipped (ToyTA22) » Reply  Edit
gaskets and syncros 100 shipped to you.
tobert5
40 posts [100%]
Garden Grove ca
hi, i would like to check it out and buy it, i could pick it up too, live in g.g. and have a vw van
tobert5
40 posts [100%]
Garden Grove ca
7147055649-text or call name is Toby
boarderboy24
83 posts [100%]
Abbotsford British Columbia
What does the kit contain?
BoRoYaSui
2033 posts [100%]
long beach ca
 Re: T50 Transmission Rebuild Kit $275 picked up or $300 shipped (boarderboy24) » Reply  Edit
moved thread http://forums.club4ag.com/zerothread?id=77723
» Return to Parts and Accessories for Sale - Toyota, Lexus, Scion and other car
