 20v haltech e6x base mapFirst  1 2 >  Last
AE86_MT
178 posts [99%]
Las Vegas NV
 20v haltech e6x base map Reply  Edit
I've tried searching to no real answers, but I have a stock silvertop 20v on a haltech e6x and was wondering if someone could send me a stock/base map for it, thanks a lot in advance. Email is tecson.mark [at] gmail.com
1985 Toyota Corolla GT-S Coupe - autocross trackwh*re - SOLD
1991 Lexus LS400 - smooth daily - SOLD
1991 Toyota MR2 - fast as hell stock car - SOLD
1986 Toyota Corolla GT-SR5 Silvertop 20valve - In the works
Grant
3656 posts [86%]
San Jose ca
You could try buggin Barry for one. He was running that haltech on a stock 20V a few years back.
Stand Alone ECU tuning. Message me for details.
Looking to buy a corolla manual rack and a TRD 3 gear transmission.
*also wtb 4 point roll cage/bar for ae86 coupe
AE86_MT
178 posts [99%]
Las Vegas NV
 Re: (Grant) » Reply  Edit
Quote, originally posted by Grant »
Thanks, I'll try to lol
AE86_MT
178 posts [99%]
Las Vegas NV
no one? got my hands on a laptop so I can do this all I need is a base map to get it back to stockkkk lol, prett pleease
Grant
3656 posts [86%]
San Jose ca
it's also not too bad to do it yourself. copy an ignition map from the megasquirt thread for 20V, and do the fuel yourself closed loop.
AE86_MT
178 posts [99%]
Las Vegas NV
thanks Grant, I'll give it a try.
rick q
60 posts [100%]
Sunshine Coast Qld
I don't know how similar they are, but I'm happy to send mine for an Haltech E8 on a Silvertop.
It runs individual coil on plug and no MAP or AFM [open ramtubes]. Cam is non-standard, but fairly mild.
Grant
3656 posts [86%]
San Jose ca
would be good for setting up the trigger timing I'm sure.
Also you guys should figure out who is using EDIS or OEM CAS
AE86_MT
178 posts [99%]
Las Vegas NV
 Re: (rick q) » Reply  Edit
Quote, originally posted by rick q »
I'm not too sure? I have never tuned or really read or have an understanding on these types of things. My Silvertop is still on the stock distributor.
rick q
60 posts [100%]
Sunshine Coast Qld
I'm not sure whether your software could read it - I'm not familiar with the E6. If you want it though, send me an email to joneseng at bigpond dot net dot au and I'll flick it back.
I know you can download the E8 Software direct from their site - you could do that just to be able to read the settings etc and manually transfer into your E6.
Might give you some base settings or something.
AE86_MT
178 posts [99%]
Las Vegas NV
Thank you, but my corolla is now sold
Hopefully the new owner has better luck tuning it then I had lol
Barry
Moderator - 9,500RPM club
6232 posts [100%]
hellaNORCAL
should have contacted me sooner. i have a good map for a blacktop on the e6x, and e6k
-barry
9500RPM Club...4AGE
wtb: AE86 16v intake box and arm.
LOTS of parts for sale, tools, AE101, AE86, jubride, RSR, TRD:
http://forums.club4ag.com/zerothread?id=86969
Hitokiri
7 posts [100%]
 Re: (Barry) » Reply  Edit
Hi Barry,
I would greatly appreciate if you could share your blacktop base map of E6X as I am still struggling with the programming. My email is Jose-Luis.Bertocchi@SC.com.
Thanks,
Josť Luis
jrmb333
1 posts [100%]
Lima
Hey Barry,
Me too, i have a Black top hachi with E6X, would greatly thanks if you could gave me the map to jrmbjesus333@hotmail.com
thanks.
Jaime.
ru2
14 posts [100%]
Sibiria Kuzbass Kemerovo city
hi Barry
if not difficult send cards 4a-ge blactop for haltech e6x
comp_ru1@mail.ru
in advance thanks
ru2
14 posts [100%]
I mean maps of ecu
ru2
14 posts [100%]
Help please with standard fuel maps under haltech e6x
andrewl
705 posts [100%]
socal ca
 Re: (ru2) » Reply  Edit
dude you ready for this? the base maps are easy.of course i run ms1 but the same stuff applies..not sure if you have afr tables but you should..first the ign events..15 deg at idle and 32deg max ..and 23deg@ cruising your range could go from 1000rpm to 8500rpm...so at 4500rpm and 50kpa tps at 20% your 23btdc..easy right? now for the fuel, drop numbers to get the idle good ..then figure the faster you go the more fuel you need..wot should be 12:1 -13:1afr..do your data logging and adjust as needed..it takes time and try to do only one adjustment at a time..and maybe post your tables for all to view..
my ms unit will kick your a$$
ru2
14 posts [100%]
hi. I'm from Russia, Siberia Kuzbas state. sometimes I do not understand that you try to explain me. Maps are necessary for start of engin, the following adjustment not problems for me.
andrewl
705 posts [100%]
socal ca
make your own base map to get the car started and adjust it.
ru2
14 posts [100%]
it is a DIFFICULT fore me to made maps myself thet is why I NEED HEPL
andrewl
705 posts [100%]
socal ca
you got a laptop?
is the ecu(haltech) hooked up to the car?
ru2
14 posts [100%]
The engine yet did not start ecu it is connected to the laptop
andrewl
705 posts [100%]
socal ca
ok you have a laptop,thats good
is the ecu connected to the engine?
i assume you speak russian
ru2
14 posts [100%]
 Re: (andrewl) » Reply  Edit
Yes I speak Russian but understanding it is a problem
andrewl
705 posts [100%]
socal ca
viktor,you online?
ru2
14 posts [100%]
yes
ru2
14 posts [100%]
help
Barry
6232 posts [100%]
hellaNORCAL
sorry guys, all of my maps are on my external drive at home in california. i have since then moved to new york.
but my maps are for the particular engine and configuration in which i tuned. you should always invest in a proper tune from a qualified tuner. mind you, not just anybody can tune. in my years of tuning i have never blown a motor, that says something. some tuners say the same, but days or months after the motor eventually blows. i have never blown a motor with any of my tunes, and thats a fact.
-barry
9500RPM Club...4AGE
J0RD0
1 posts [100%]
Brisbane QLD
Thread dig, Hey Barry do you by chance have these maps still?
 First  1 2 >  Last
