 ToeKnees slow build..First  < 1 2 3 >  Last
superdougy
573 posts [100%]
San Ramon Ca
 Re: (ToeKnee805) » Reply  Edit
Tony...Update your thread so I have something to read while I sit on my a$$ in Tokyo.
Moving Nov 4th!! Seibon, TRD, Greddy, Prothane plus FREE PARTS!!!!
http://forums.club4ag.com/zerothread?id=112409
!961 Mini AWD b20
http://www.superfastminis.com/AWD_MINI.htm
!985 Toyota Corolla GTS Levin f22c
http://forums.club4ag.com/zero...86909
ToeKnee805
613 posts [90%]
Santa Paula California
 Re: (superdougy) » Reply  Edit
12/18/10
Well i broke in the engine. Gonna do the oil change tommorow, and go to the track sunday! Hooray for abusing brand new engines!
In other news I got this puppy to finish off my kit.
Test fitment,Fitments pretty legit <img name="icon" src="http://xs-s.com/zf/images/smile/emsmile.gif" border="0"> I also relocated my license plate to the right. Lets go to the track!!!
12/19/10
Went to the justDrift Toydrive had a blast in the rain, heres some shots of the rolla with the new motr.
Coming to a SuperStreet Near you
<br /><br />
Modified by ToeKnee805 at 9:06 PM 3/28/2012
Modified by ToeKnee805 at 11:02 AM 10/5/2012
1986 Corolla GT-S
1989 240SX Hatch
http://www.facebook.com/805LIDE
ToeKnee805
613 posts [90%]
DMAX roof wing. And i lowered it just a tad..
It took me almost 2 months, but it was well worth it, since I got em for CHEEEEEEEEAP. Hooray for working at a Toyota Stealership!
Heres an update thats actually worth clicking my thread for haha
I finally gathered all my parts for my Manual Rack conversion.
TE72 Manual Rack, Ujoint, and Intermediate Shaft.
I hooked it up with some TechnoToyTuning Outer Tie Rods and Beefy Knuckles. I also bought a BattleVersion rack spacer, but I was antsy to put the rack in, I decided to throw it on later when I have time to pick it up from Alex.
Since the PS Pump, Idler, and AC compressor run on the same belt, everyone deletes the AC at the same time as PS. But **** that I love my AC, so i junkyard hopped around and found an MR2 AC bracket(MR2s never came PS) and it bolts right up to my block, which lets me run an MR2 AC belt, which enables me to keep my AC and delete PS.
Old Rack
Old Pump, Lines, Reservoir, Brackets
Fitting the Manual rack in
Right after setting it in
Megan Coils, DGARAGE RCAs, T3 Knuckles, T3 Tie Rods, SS Brake Lines
All i need are Tension Rods and a Sway bar and my front suspension would be complete.
Angle without centering the rack, or Doing my alignment
1/4 Turn before FULL LOCK. I cant go to full lock at the moment because my tires rub on the Frame Rails.
These are all set with the knuckles on the stock setting, no rack spacers, -1.5 Camber, 2.25 Caster, 0 Toe.
Modified by ToeKnee805 at 9:07 PM 3/28/2012
1986 Corolla GT-S
1989 240SX Hatch
Deuce Cam
1029 posts [100%]
Chandler AZ
Ideally you want to connect the outer tie rods to the underside of the knuckle, not on top. If you run them on top of the knuckles you'll notice that the tie rods are actually slightly angled up when the car is at ride height which isn't good (tie rods angled up, control arms angled down could lead to some weird steering characteristics). Also, you want the tapered part of the outer tie rod spacers touching the tie rod end so it can move in a wider range of motion without hitting the spacer. Mounting the nut right up against the tie rod end isn't good either.
I just went through this whole debacle with installing a manual rack, t3 knuckles/outer tie rods and t3 rca's. Initially I had it set up basically how you did because it seemed like it was the only way it could work (tie rod ends wouldn't angle down far enough to mount below the knuckles with the suspension at full droop). I knew it wasn't right because of the angle of the tie rods and the steering felt weird, also the stock setup mounts below the knuckle. I talked to Gabe at t3 and he explained basically what I did above. I had to remove the rca's so I could actually get the t3 rod ends to mount below the knuckles without any binding (suspension at full droop). Luckily I'm not reall dropped so it's not a big deal. Steering feels WAY better.
Parts for sale:
http://forums.club4ag.com/zerothread?id=99639
ToeKnee805
613 posts [90%]
 Re: (Deuce Cam) » Reply  Edit
Thanks for your input, i was wondering what the right way was, and the way you explain it makes complete sense. I did have a feeling my steering felt off, but i just thought that was the nature of the manual rack. Ill try to re do it the right way before i try to slide it.
1986 Corolla GT-S
1989 240SX Hatch
ToeKnee805
613 posts [90%]
 Re: The Drift Booger! by ToeKnee805 (ToeKnee805) » Reply  Edit
Does this look right?
1986 Corolla GT-S
1989 240SX Hatch
ToeKnee805
613 posts [90%]
Went to a carshow sponsored by DCH Toyota of Oxnard (my employer) and another corolla showed up
Then decided to reupholster my sparco...
Sported it March 28th at the JustDrift event..
6/10/11
Came up on Tension Rods!
And ditched the ae92 skirts for some Vertex ones to complete my kit.
8/9/11
Got the car smogged, and it passed with flying colors, so I know I atleast learned something in school
9/3/11
The waterpump took a ****, so I had to replace it right before I went back to the track
9/4/11
JustDrift Sep 4, 2011 Clinic
OOPS Bye bye bumpers
So after the track I decided that I no longer wanted a POS looking track slut. So i decided to try and clean her up...My inspiration..
Step 1:
11/11/11
JDM Kouki Sprinter Trueno Bumper.... CHECK!
JDM Kouki Sprinter Trueno Turn Signals.... CHECK!
Step 2:
JDM Zenki Lip.... CHECK!
Step 3:
jBLood Skirts.... CHECK!
Bumper and Lip Marriage
Just need a JDM Kouki Rear Bumper with jBLood rear valences, and it will be ready for paint. After paint im looking at getting those Work Equip 03's, Only $1600 for just the wheels hahaha.
1986 Corolla GT-S
1989 240SX Hatch
ToeKnee805
613 posts [90%]
Got a rear JDM Kouki Bumper
and some jBlood valences..
NST hooked me up with a Steering Spacer.
And off to paint she goes...
While at paint EP Importers hooked me up with some SPRINTER Tails..
Went to Visit my car a month later..
Molded Wing <3
First pictures I got from the paintman
Done :D
And thats how i sit today :D
1986 Corolla GT-S
1989 240SX Hatch
Jeonsah
1814 posts [95%]
Co
I approve your car build man. The fact that it was wrecked and you painted it back the oem color is nice. Nice car man
WTB AE86 Best Motoring International Vol. 42. Pm if you have it!
Rookie86erinVegas
1921 posts [99%]
Lol you know what's so crazy as I was slowly scrolling down reading your build I kept thinking to myself "he should've kept that car the stock blue or something close and that green looked horrible" then I see your inspiration car towards the end and I laughed! Good job on the build man I'm glad you got "inspired"
torque88
88 posts [100%]
Camarillo Ca
Looking good. I dig it. Just need to get mine running
ToeKnee805
613 posts [90%]
 Re: (Rookie86erinVegas) » Reply  Edit
@Rookie86er.. haha So far I have gotten mixed feedback. What made me change was one day being bored and going on the "PICTURE OF YOUR CAR THREAD" and going through all (80 pages at the time) and everytime I saw a stock blue car i told myself: "F**k man, I need to go back to stock blue" so one day I decided that im cleaning the car up, throwing away the kit and going OEM JDM, and OEM Paint. It was ***** expensive but well worth it. To me the car looks a million times better.
Some have said the color isnt the "right" one, and some have said Green was more "me". But how is a stock color not the "right" one...? Others have told me it needed to be blue and they're so excited to see it blue now.
Everyone agrees though that the paint came out immaculate.
Next up and exhaust and a CF hood. Then maybe some Equip 03's.
@torque: we need to meet up when its running, were so close from eachother.
1986 Corolla GT-S
1989 240SX Hatch
corollarollas
6543 posts [90%]
it was like.
i want a clean corolla.
BAMMM clean corolla.
good job man, very inspirational.
ToeKnee805
613 posts [90%]
 Re: (corollarollas) » Reply  Edit
Haha thanks
So my old exhaust fell off at some railroad tracks
And I deliver with a SUPEROMG Rare 5Zigen Border 3 exhaust straight from Group A Motoring. Thanks again Simon you always come through.
You can see more of the paint of how it fades to gray in the dark.. Also the TRD Wing and DMAX Roof Spoiler.
1986 Corolla GT-S
1989 240SX Hatch
Jeonsah
1814 posts [95%]
Co
Nice exhaust. I think you should try to bump the muffler up a little bit so its tucked in more. Otherwise i really like that setup. Nice job man!
*waits for nice wheels and photoshoot*
ToeKnee805
613 posts [90%]
 Re: (Jeonsah) » Reply  Edit
I was actually missing a few exhaust donuts when my exhaust fell off, i went to Autozone and bought some and replaced all the missing ones, and it sits nice and tucked into the Bumper hole. VERY nice fitment from 5zigen.
1986 Corolla GT-S
1989 240SX Hatch
ToeKnee805
613 posts [90%]
Finally put on my NST Spacer
Car is not full Lock, my JIC Magic tension rods bind on my T3 Knuckles, I need thinner Tension Rods
Modified by ToeKnee805 at 12:45 AM 4/16/2012
1986 Corolla GT-S
1989 240SX Hatch
Toy86
354 posts [100%]
Crestview FL
Great build bro, i'm glad you came to your sense, and fixed her up. lol One question for you bro; where did you get ur Zenki Lip from and how much? Thanks a million.
Toy86
ae86@661
716 posts [100%]
great build the car is looking nice
ToeKnee805
613 posts [90%]
 Re: (ae86@661) » Reply  Edit
I bought them from K1 Motoring, the forum username is YVERSION i believe. He had about 10 for 350 a pop Brand New in wrapper
1986 Corolla GT-S
1989 240SX Hatch
Toy86
354 posts [100%]
Crestview FL
Thanks man, i appreciate the info.
ToeKnee805
613 posts [90%]
 Re: (Toy86) » Reply  Edit
Modified my tension rods to make clearance for my knuckles, can finally acheive full lock..
Chillin at our shop..
Track event this sunday, next pictures will be action shots
1986 Corolla GT-S
1989 240SX Hatch
ToeKnee805
613 posts [90%]
ok ok last update before the track..
1986 Corolla GT-S
1989 240SX Hatch
ToeKnee805
613 posts [90%]
Rough cut track footage..
http://www.youtube.com/watch?v=8vSQiENeWWA
Anybody have any constructive criticism for me? I tend to Understeer quite a bit and my rear end is bouncy at times...
1986 Corolla GT-S
1989 240SX Hatch
Warren
194 posts [93%]
Victoria BC
What were you running for rears? I would try a set of ***** 175/65/14 or 185/60/14 at 60psi, I looked like you were loosing a lot of speed.
ToeKnee805
613 posts [90%]
 Re: (Warren) » Reply  Edit
I was running 185/60/14 Fuzion HRis which are crappy econo tires, but I had them set at like 35 psi. Ill try to bump them up to 60 next track event, alot of people have told me I wasnt carrying speed all the way through the course. I messed with the damping on the rear coilovers, and tried clutch kicking more often but i didnt even think about my PSI. D'oh haha
1986 Corolla GT-S
1989 240SX Hatch
StevenEngage
95 posts [100%]
Oakdale ca
Just read this whole thread, I have been debating painting mine lime green, looks pretty good but that stock blue looks gorgeous! lol
Nice car man.
1985 Corolla GTS hatch
2009 Toyota Corolla S
Warren
194 posts [93%]
Victoria BC
Considering how smooth that tracked looked I would just go for stiff, there will be no issue keeping the tires on the ground.
GARAGE_86
the artist formerly known as
6879 posts [100%]
Master P.
Quote »
hmmm i use to instruct at willow before and i know balcony pretty well like the back of my head ..theres alot of hidden bumps ,you need to know where to place your car esp with a stock motor 86 to get thru ..trust me i know
watchin you , alot of your reaction is delayed ..change the front track or wheels of your car so you dont under a lil or ,pump the rear higher like you said ...youre gettin too lost in your wheel and the way you settle the car seems like your chasin it more than your controllin it ...your timing in initiation is all off ..... just practice more ..you remind of carlos (your idol) when he started out , very twitchy and car acts so stiff and weird and too choppy (i use to give him lots of advice when he started or when he staffed for us) ...but you'll get it ..hope that helps dont give up,dont cut corners and dont upgrade your motor yet ..you'll know what im sayin in the future
goodluck
AE86Nights
Tigere Llantas
"From all the years , I learned not everyone in a AE86 corolla is automatically your friend ...A car doesn't make someone automatically a TRUSTED person "
-------OEM Manual Rack sets or Hybrid sets ---- hmu thru pm < RACK CITY
-------OEM non-cruise throttle cables for sale ----
http://forums.club4ag.com/zerothread?id=64669
-----------------15x10 wheels for sale------------------------
http://forums.club4ag.com/zerothread?id=112591
ToeKnee805
613 posts [90%]
 Re: (GARAGE_86) » Reply  Edit
I plan on sticking with the built 16v for a while. How can I got form chasing the car to controlling it? Just practice? Or is there something specifically im doing wrong that I need to stop doing?
1986 Corolla GT-S
1989 240SX Hatch
