 ToeKnees slow build..First  < 2 3   Last
Warren
194 posts [93%]
Victoria BC
The more you drive the more your will know what is going to happen. But you are doing great, seat time!
ToeKnee805
613 posts [90%]
Santa Paula California
 Re: (Warren) » Reply  Edit
I was talking to a buddy of mine, not sure his forum name, but we went over my alignement specs and before i head back out im gonna switch things up a bit.
Current:
Camber: -1.5
Caster: +3.25
Toe: 0
Adjusting to:
Camber -3.25
Caster +2.75
Toe: 0
1986 Corolla GT-S
1989 240SX Hatch
http://www.facebook.com/805LIDE
Warren
194 posts [93%]
Victoria BC
I'm still a big caster pusher. I run 6-7 degrees of it.
ToeKnee805
613 posts [90%]
Wow really? I like the snappyness of +3,25, but for now i think im not at the reflex speed to catch it when its that snappy. What camber do you run?
In other news, I got some MR2 AW11 fans and threw them on with an AE92 Temp sensor. I have plenty of space up front, but If i want to get an Aftermarket Radiator id have to Delete my AC as the fanshroud already hits the AC Pressure hose. And just to note, the OEM snorket Up tube will not fit withthis shroud unless you delete the AC lines.
2 Relays just chillin.. you can see some of the wiring on the side of the airbox
Small video of My Temp Gauge with the Fans on... as I start to walk away they turn off, and you can hear my Pilot bearing clacking around... and a crappy view of the Temp Sensor with AE92 WaterHousing.
1986 Corolla GT-S
1989 240SX Hatch
Warren
194 posts [93%]
Victoria BC
I dont find that castor really effects snappyness, that is more from how quick your car transfers weight. The more castor I run the more the steering wants to track, it does get heavier, but I find its worth it when it comes to really really fast but safe transitions. I run around 5 degrees of camber.
If you are only planning on running 2-3 degrees of camber may 4-5 degrees of castor would feel the same as my steering. This was all with my modded S13 knuckles. So I probably had all sorts of geometry **** coming into play.
edit:
Here is a video of my car from last year. This track/layout if a bad example of quick transitions without fighting the wheel because there is no transitions where I am not trying to push hard to make the next apex. But its the only video I have of the steering wheel.
With all the low castor numbers that Corolla people, and only Corolla people run, you would normally see the driver chasing and fighting the wheel to keep the wheel pointed forwards. The steering would be very light and pleasant but still fighting. This is not to say that it cant be mastered, my buddy in his SR86 here runs around 3 degrees, he kills it, and is snappy as all hell.
You can see that my front track the ground perfect, and all that I am doing is giving input to change my line. This makes your car as easy to drive as a 240, while keeping at response and quick nature that we all love.
http://www.youtube.com/watch?v=YlCws4LxkKY
Some clips in videos of the setup.
http://www.youtube.com/watch?f...=131s
http://www.youtube.com/watch?f...t=30s
http://www.youtube.com/watch?v=R4j292kW-lg
GARAGE_86
the artist formerly known as
6879 posts [100%]
Master P.
 Re: (ToeKnee805) » Reply  Edit
Quote »
Adjusting to:
Camber -3.25
Caster +2.75
Toe: 0
we went over this caster talk in the old drifters thread too much , each is is his own but for this car i wouldnt run too much
thats a good base up there goodluck
AE86Nights
Tigere Llantas
"From all the years , I learned not everyone in a AE86 corolla is automatically your friend ...A car doesn't make someone automatically a TRUSTED person "
-------OEM Manual Rack sets or Hybrid sets ---- hmu thru pm < RACK CITY
-------OEM non-cruise throttle cables for sale ----
http://forums.club4ag.com/zerothread?id=64669
-----------------15x10 wheels for sale------------------------
http://forums.club4ag.com/zerothread?id=112591
yellowsnow4free
303 posts [100%]
ToeKnee805, could you give me some more info on the AW11 fan setup? I've been thinking about going to electric fans for a while now.
What would I need off the MR2? The fans and the 2 relays? Also, I've read the temp sensor off a FWD 4AC works too:
http://www.dreamsofdrifting.co...x.htm
How do you like it?
Finally, (unless it's secret) what's this switch?
My car doesn't have that.
Cutting up an AE86? Please me know! I need body panels!
Petition to Reinstate the CA 30 Year Smog Exemption
ToeKnee805
613 posts [90%]
 Re: (yellowsnow4free) » Reply  Edit
Yeah the AW11 Fan conversion is pretty easy. All you need from the AW11 is the Fans with Shroud. And 2 Relays, About a Spool of 20 Gauge wire, an Inline Fuse Holder, a 30A fuse, and some Soldering supplies(or butt connectors)
Not sure on the 4ac Temp sensor, but I got mine from an FX16 GT-S, which is an ae92 Hatchback pretty much.
You will also need the accompanying Oring Seal, and Thermostat.
This is the diagram I used...
Wiring the fans probably took about an Hr or two, Insalling probly the same. Hard part is routing the wiring so you cant see it.
And so far so good, I like it. Im running same temps as I normally would iwth a clutch fan, but I can feel the engine rev up a little quicker and you can hear it in the exhaust that it has less load.
And finally that switch only comes with Hatchback corollas, it is for the Rear Window defroster. :)
1986 Corolla GT-S
1989 240SX Hatch
ToeKnee805
613 posts [90%]
http://www.youtube.com/watch?v...inbox
Frames bent, shock tower pushed back, and core support is damned.
tube front end here i come
1986 Corolla GT-S
1989 240SX Hatch
GodLovesUgly
154 posts [100%]
Calgary Alberta
I shed a tear when I saw the vid, that was rough. Happy everyone was ok though, and even more happy that your not gonna give up!
torque88
88 posts [100%]
Camarillo Ca
That straight blows!
I have a shell I'm gonna be getting rid of tomorrow.
Txt me if you want anything off of it to get yours back on the streets. I have no problem hacking it up.
805.432.5558
superdougy
573 posts [100%]
San Ramon Ca
That sucks! Seems like you really couldn't avoid it. Glad everyone is okay. Don't fix it, UP Grade it. Bigger, Better, Faster!! That's what I do.
Moving Nov 4th!! Seibon, TRD, Greddy, Prothane plus FREE PARTS!!!!
http://forums.club4ag.com/zerothread?id=112409
!961 Mini AWD b20
http://www.superfastminis.com/AWD_MINI.htm
!985 Toyota Corolla GTS Levin f22c
http://forums.club4ag.com/zero...86909
GARAGE_86
6879 posts [100%]
Master P.
years ago 2006 below...there was always a rule in WSIR or any drift event at socal..JD or DD.. that says :
no tandem or htm unless advanced or more than 5 events on the belt or unless permission from an instructor
couple of yrs ago other events joined in and forgot that rule and everythin went whatever .. ahem 7 car tandem w/ kids ..poorly handled events etc
sorry to chime in ..but many accidents in drifting are cause by inexperienced drivers ..i never follow or tandem with anyone who simply spins out on initiation or even transition ..not worth my time swapping a shell
goodluck dude
AE86Nights
Tigere Llantas
ToeKnee805
613 posts [90%]
 Re: (GARAGE_86) » Reply  Edit
Carlos was driving, didnt expect him to spin out. And it was a private event no instructors
1986 Corolla GT-S
1989 240SX Hatch
GARAGE_86
6879 posts [100%]
Master P.
Quote, originally posted by ToeKnee805 »
from all his old friends xoxo
AE86Nights
Tigere Llantas
ToeKnee805
613 posts [90%]
Dont see why you dislike him so much. Hes a legit guy and no matter how much experience you have, everyone spins.
1986 Corolla GT-S
1989 240SX Hatch
GARAGE_86
6879 posts [100%]
Master P.
i never said i dont like carlos dude..i just dont see him makin that mistake after all these years ..i know youre just backin up your idol but mistakes happen
AE86Nights
Tigere Llantas
ToeKnee805
613 posts [90%]
Its back... woohoo
After a Frame Pull, new Passenger fender, new Corner Light, New Eyelid, and the complete front end repainted...
I think im gonna need a new JDM Bumper... Anyone down to buy this one off me? Haha Bumper fits fine, it just isnt bolted due to the caster im running rubs on the bolts.
1986 Corolla GT-S
1989 240SX Hatch
ToeKnee805
613 posts [90%]
New wheels and new Painted bumper.
I did run 15x9 +15 all around, but the front wouldn't fit, and with 15 mill spacers they would stick out TOO much. So I went down to 15x8 0 offset for the front and 15x9 +15(w/ 20mm Spacer) in the rear. Running 195/50/15 on both the 8 wides and 9 wides. I gotta lower the rear a lil more, the stretched tire makes the car look super high in the rear.
We got some new club stickers made out of Reflective Vinyl that they use on Firefighter Trucks, Cop Cars, and Ambulances..
Day TOP, Night BOTTOM(No enhancements or Filters on these images)
Unfortunately in the accident my cars differential Broke, so now it peg legs. In the process of Buying a TRD 2 way.
Also go ahead and like us on facebook were currently working on paperwork to get some local track events up at the old DriftDay spot in Camarillo,CA.
facebook.com/805lide
1986 Corolla GT-S
1989 240SX Hatch
superdougy
573 posts [100%]
San Ramon Ca
Looks good... Again.
!961 Mini AWD b20
ToeKnee805
613 posts [90%]
 Re: (superdougy) » Reply  Edit
Bolt in Cage to be welded. Previous owner said it was an Autopower, but never seen an autopower like this.
1986 Corolla GT-S
1989 240SX Hatch
GtsTone23
3595 posts [99%]
Chicago IllaNoise
I like the Never QUIT in you Bro .... Many would have sold that car after the first crash. Keep up the good work!
Peace ~ Tone
"Behind every Successful Man lies a Pack of HATERS,
If they aint Hating Now, They'll be Hating Later"
~GtsTone23~
grappletech
280 posts [100%]
Co
holy crap man, i have one of your pics as my wallpaper and didnt even know it
AE86 A.K.A Trouble!
http://forums.club4ag.com/zerothread?id=97019
WTB: GTS seats. I need some ASAP!
Honoturtle
541 posts [100%]
Honolulu HI
Wheels look great. Is there any difference in the size of the lip between the 8" and 9" rim?
Coupe Sprinter. Precision. Style. Strength. Toyota.
ToeKnee805
613 posts [90%]
 Re: (Honoturtle) » Reply  Edit
Yeah I believe the 8inch is a 2 inch lip or 2.5, and the 9 is a 3inch lip
1986 Corolla GT-S
1989 240SX Hatch
ToeKnee805
613 posts [90%]
 Re: (grappletech) » Reply  Edit
Quote, originally posted by grappletech »
Haha which one? Im flattered that my car is wallpaper material
1986 Corolla GT-S
1989 240SX Hatch
 First  < 2 3   Last
