 Converting auto to manuel?
Burning_Inner_Strength
18 posts [100%]
Foresthill CA
 Converting auto to manuel? Reply  Edit
What am I really looking at when i want to convert my auto aw11 to a manuel? Just how much it would be...etc...
assassin10000
Teq
4959 posts [100%]
Northern CA
 Re: Converting auto to manuel? (Burning_Inner_Strength) » Reply  Edit
Just an FYI, a little searching will go a LONG ways.
AND you may have some good luck checking the forums at http://www.mr2oc.com & http://www.mr2.com as they're may be write-ups there about doing this.
Cost will depend on what your able to find parts for... and of course whether or not you use new parts or reseal the trans. Well suffice it to say it a LOT of money can be spent or a little depending on how good you are at hunting down deals.
Andrew
18 posts [100%]
Foresthill CA
 Re: Converting auto to manuel? (assassin10000) » Reply  Edit
thank you very much for the tip and links! have you ever done something like this sort of project?
rooster
52 posts [98%]
solvay newyork
i already have a 5spd on my aw11 but over the winter i was gunna swap out the stock motor an tranny w/ the 20 v black top an a 6 spd tranny not sure how im gunna do it yet but im sure with some inginiuty it can b done so far i think the hardest part is gunna b the ecu an wireing im hopin w/ a 12 pk of beer an a cpl of my cousins we can figure it out @ this point tho my focus is 2 get the lookin an ridin nice then im gunna work on buildin up hp
Randomist
259 posts [98%]
MT MEE QLD
 Re: Converting auto to manuel? (rooster) » Reply  Edit
thats always a good way to do it rooster good luck with the 20valve
as to the gearbox, i think unfortunantly the wiring and ecu will need to be swapped out along withthe gearbox as well as the shift plate inside the car and possibly the centre console
find someone near you with a manual mr2 who wants a auto and just swap XD
at the very least check the similarities and differences between the 2 models ^_-
AW 11 - the original and the best
18 posts [100%]
Foresthill CA
 Re: Converting auto to manuel? (Randomist) » Reply  Edit
Really? well i live in california, it's really hard to find similar models but thank you for the tip. i will look into it. and would i have to change the ECU also because im converting? i really need to look more into this. also if it's not too much of a bother. do you know if ITB's can pass smog? im really thinking about getting them but im just wondering about the process and all.
2many2sAW11
5 posts [100%]
knoxville tn
i dont know if you have already done the swap/given up on the swap but you need the 5 spd trans. clutch pedal, hydraulic line, master and slave cyl, shifter w/ linkages, and a new clutch. if you want i can do a write up on the whole process. the ecu and wiring works with both. just let me know if anyone wants me to make a post on it
current cars:
85 aw11
86 aw11
88 aw11(20 valve)
78 280z turbo
i have a slight addiction :P
Rey Trossi
637 posts [100%]
Bay Shore NY
 Re: Converting auto to manuel? (2many2sAW11) » Reply  Edit
I just did the swap like a month ago. Car feels a lot faster. The is two issues that I have to solve one that the overdrive light in the dash keeps blinking and that the rpm is a bit high. But was not very hard to do. I had a non running 85 mr2 so I took everything I needed from that one. I should have done the swap a long time ago. Now planning to install a better trany I have a c50 from the 85 mr2. No issues with the trany so far. Would love to install a 6spd.
