 San Francisco Levin buildFirst  < 13 14 15 16 17 >  Last
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (Grant) » Reply  Edit
Hi Grant, I was hoping to but won't be able to make it. Really looking forward to seeing the pictures though.
gaijin_rokurunner
1990 posts [100%]
UPPER MARLBORO MD
 Re: (Billy_Andrea) » Reply  Edit
Billy Did they ever get around to Dynoing your 20v? Curious to see what kind of numbers it puts out
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (gaijin_rokurunner) » Reply  Edit
I was over there on Saturday & everything is hooked up on the dyno. The map is done but they were having communication problems between the crank trigger & the ecu ( AEM EMS4 ). The crank trigger is providing a signal as expected but the ECU isn't seeing it. They're working with AEM to get it figured out. Seeing it on the dyno made me say "damn, that engine looks so much better than the 16v"
gaijin_rokurunner
1990 posts [100%]
UPPER MARLBORO MD
Ohhhhh AEM strikes again lol why don't u switch to COPs and use the stock dist as a CAS
Billy_Andrea
1321 posts [100%]
San Francisco CA
Already using COPs but running them on batch fire based on the crank trigger. If something doesn't change very soon I will be switching ECUs.
Grant
3656 posts [86%]
San Jose ca
billy what kind of cam angle sensor are they using? I had some trouble myself but got it sorted
Stand Alone ECU tuning. Message me for details.
Looking to buy a corolla manual rack and a TRD 3 gear transmission.
*also wtb 4 point roll cage/bar for ae86 coupe
Grant
3656 posts [86%]
San Jose ca
the AEM EMS4 can only take a rising edge signal and i think the 20V is falling edge. The polarity on the wires has to be switched and the shielding of the CAS wires is critical! Its a really fragile setup.
gaijin_rokurunner
1990 posts [100%]
UPPER MARLBORO MD
Im using an adaptronic with my setup...came with base map and everything
enrike
126 posts [100%]
Petaluma CA
 Re: San Francisco Levin build (Billy_Andrea) » Reply  Edit
Love this build. Keep up the amazing work!
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: San Francisco Levin build (enrike) » Reply  Edit
This morning the 20v made 210bhp at 8,500rpm & 140lbs of torque on pump gas.
Waiting on the dyno sheet from Hasselgren.
I thought with these cams that it's a great result. He said with bigger cams, more compression & a few more revs ( revs depend on the bigger cams ) it could close in on 220bhp.
Coldvaper
801 posts [100%]
SF CA
Impressive numbers to be sure.
ian
156 posts [100%]
 Re: (Coldvaper) » Reply  Edit
billy where did you get the crank sensor and assembly from
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (ian) » Reply  Edit
Hasselgren supplied it. I believe it came with the 1.8L front cover.
They made the trigger wheel themselves.
assassin10000
Teq
4959 posts [100%]
Northern CA
Very nice! Hopefully I'll get a chance to see it in person.
Andrew
Billy_Andrea
1321 posts [100%]
San Francisco CA
Grant, no cam angle sensor. Batch fire based on the crank sensor.
Andrew, you will hopefully see it in one of my friends cars at an upcoming meet. I'm picking up my 16v tomorrow.
Here's the 20v in my shop waiting for it's new engine bay:
Billy_Andrea
1321 posts [100%]
San Francisco CA
Picked up the 16v yesterday, finally! Can't wait to start the install. It came complete with all sensors & harness as well as sub harnesses.
Grant
3656 posts [86%]
San Jose ca
This is for a daily driver right? Go hard or go home.
Billy_Andrea
1321 posts [100%]
San Francisco CA
Certainly is. I'm going to drive this thing to work!
Modified by Billy_Andrea at 7:38 AM 9/10/2012
mikeyee
1697 posts [96%]
Fremont ca
hhoollllyyyyyyy. fuel injectors shooting from outside the trumpets?!!
(゚o゚;;
googod, this is one crazy build! cant wait til you bring it out!
http://about.me/myee
Mike Yee's Corolla resource page: https://sites.google.com/site/ncalae86/resources-1
Jan Pedersen
531 posts [100%]
Awesome stuff
I can't wait to see dyno plots for all these great engines
'86 Euro Levin Project
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (Jan Pedersen) » Reply  Edit
Thanks guys.
I tried on the exhaust last night. Should be ready to start the swap by the end of the month.
This is the entire engine harness !
kouki1986
1232 posts [100%]
honolulu hawaii
This engine will be the screaming eagle on the street. People can't resist to ask you whats in the hood.
http://www.carbonfibercollection.com
carbonfibercollection@yahoo.com
smashfactory
257 posts [100%]
Hollywood CA
more updates!
friggin'
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (smashfactory) » Reply  Edit
Not much of an update as work has been pretty hectic.
I finally decided on exactly where & how to mount the oil tank in the trunk. I used 2 pieces of aluminum, one bent in a press to match the shape of the inside of the spare wheel well with the vertical piece drilled, tapped & welded to it. It needs to be tidied up but you get the idea. I will also drill the trunk floor to allow me to drain the tank oil without lifting the car.
The clutch kit also arrived from Hasselgren. It's a Tilton twin disc with a Mazda splined hub & billet pressure plate and a 3kg flywheel. Just waiting for the chassis harness and it's full steam ahead.
mikeyee
1697 posts [96%]
Fremont ca
hmmmm!
going mazda tranny route?
Billy_Andrea
1321 posts [100%]
San Francisco CA
 Re: (mikeyee) » Reply  Edit
Yep, Mazda 5 speed from the Turbo II
gaijin_rokurunner
1990 posts [100%]
UPPER MARLBORO MD
Billy what were the specs on the 20v engine as far as cams bore size and C/R? Curious to know so I can make a educated guess of what my engine will make being i will have 200cc more then u, running 13/1 with 300 duration 10.7mm lift cams and the bunch of other goodies Ive done
Billy_Andrea
1321 posts [100%]
San Francisco CA
The bore size is stock.
Cams are 9.55mm lift intake, 8.5mm lift exhaust. Duration is 284 for both.
Compression is 11.5:1. The block was hot honed which they say makes a big difference.
gaijin_rokurunner
1990 posts [100%]
UPPER MARLBORO MD
cool Quick Silver Race Engines is building my engine...they are one of the founding formula class engine builders along side Loyning....now my expectations are very high being that im 83mm bore, alot higher in C/R then yours, and a lot higher lift...not to mention the extensive DLC, WPC treatment and dry film coatings I have on parts and through out the engine...im hoping that frees up a lot of the loss from friction. I also got the custom valves from Ferrea.....you went with the supertech oversize correct? I will talk to you offline about those...dont want to hurt nobodies feelings here......your cams were the kelford correct?
Grant
3656 posts [86%]
San Jose ca
wow
