 ne1 runnin aftermarket ecu s ???
rooster
52 posts [98%]
solvay newyork
 ne1 runnin aftermarket ecu s ??? Reply  Edit
im curious about what brands of aftermarket ecu s are out there an what the benefits are over having stock ecu s flashed ?
Mulder
284 posts [99%]
sandpoint id
 Re: ne1 runnin aftermarket ecu s ??? (rooster) » Reply  Edit
I dont think there's much of anything available anymore on the market other than completely programmable ECU's like Megasquirt.
-Mulder
Black '86 MR2 20v
-I may be small but I am strong and I'll get it on with you!
Randomist
259 posts [98%]
MT MEE QLD
 Re: ne1 runnin aftermarket ecu s ??? (Mulder) » Reply  Edit
yeah, a few people over here run ms2 , mostly the v6 guys im going to use ms2 as well with my 9age, dont think there is much else available, a company in europe makes something very similar to the megasquirt but its more expensive and harder to obtain over here so ms2 or nothing
AW 11 - the original and the best
13133 posts [99%]
Portland
unit installed in my car
http://www.fjoracing.com/products/341B
Features
•Direct control of fuel delivery system with self-tuning feature
•Integrated high energy direct-fire ignition system or support for OEM Coil-on-Plug ignitions
•Easy to use graphic set-up menus and datalogging using a laptop
•User defined configuration tables
•8 trigger inputs
•15 sensor inputs to monitor and protect the engine
•21 control outputs (can be used for functions such as nitrous control, boost control, VVT, etc)
•Wireless link for datalogging/tuning
•Integrated GPS
rooster
52 posts [98%]
solvay newyork
 Re: (oldeskewltoy) » Reply  Edit
just found my password lol how much is the ms or ms2 runnin $ wise vs what ur runnin ??? i like the pic ty
Mulder
284 posts [99%]
sandpoint id
 Re: (rooster) » Reply  Edit
MS2 is in the $250-$400 depending on where you buy and whether it's assembled or needs assembly. At least that's what it was when I last looked a few years ago. DIYautotune.com was a great website for them.
-Mulder
Black '86 MR2 20v
rooster
52 posts [98%]
solvay newyork
 Re: (Mulder) » Reply  Edit
is the ms 2 plug an play ???
rooster
52 posts [98%]
solvay newyork
whats the difference between the ms 2 and a standalone ???
Mulder
284 posts [99%]
sandpoint id
No, it's not plug and play. MS2 is a standalone ECU. It's completely programmable, but takes a lot of time and knowledge to set it up with the proper inputs/outputs/wiring/sensors and to make a proper fuel map. I spent a year reading all the info I could get my hands on about making it work but finally gave up and sold the thing. Such an undertaking is not for the faint of heart, and if you look on this forum, you'll find thousands of people who tried and failed to make it work.
Doesn't sound like it's the right option for you if you're asking if it's plug and play.
-Mulder
Black '86 MR2 20v
rooster
52 posts [98%]
solvay newyork
i gotta agree with u there im deff not competent enough 2 program that however my boss is well versed in the physics behind an engine id have 2 talk 2 him an c if its something he could help me program altho he is more into chevy an gm products over toyota but he has built motorcycle engines that have reached 300 hp
