 DIY Parts List: Full Flow Aftermarket Oil CoolerFirst  1 2 >  Last
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
 DIY Parts List: Full Flow Aftermarket Oil Cooler Reply  Edit
The following is the parts required to build your very own full-flow aftermarket oil
cooler. Some of you may be saying though: "Well I have a GTS OEM oil cooler, do
I need this and why?"
From my own findings:
For daily driving or the occasional weekend warrior, I find that no oil cooler or just
running the stock GTS cooler will be just fine. Those of you that auto-cross or grip
drive may want to upgrade, but it may not be necessary depending on how long
your run sessions are. Same goes for you occasional drifters. I HIGHLY
recommend this upgrade to any of you that plan on doing 15+ min continuous run
sessions.
The oil temps get up there. I blew my first 20v engine doing 45 minute
straight, non-stop drift sessions. Coolant temps were fine, but the engine oil just
couldn't hold up.
The OEM GTS unit is not a full-flow oil cooler. It has a pressure-sensitive check
valve that stops flow at low oil pressure/low rpm and allows flow at high oil
pressure/high rpm. The OEM GTS oil cooler only allows oil to flow through it as
engine rpm increases. At idle there is little flow if any. It does not work all the time.
This oil cooler setup that I am running is a MOCAL setup using a thermostatic
adapter plate. The sandwich plate contains a thermostat that restricts flow to the oil
cooler until the engine is up to the proper temperature, allowing the engine to warm
up properly and reducing premature wear on the engine.
Enough ranting.....
Stuffs you needs
-13 row MOCAL oil cooler w/ -8AN fittings (part number MOC-13208)
-MOCAL adapter plate (part number MOC-SP1T)
- -8AN straight swivel fittings, FOUR NEEDED (part number AER-FCM1013)
- 1/2" BSP to -8AN fittings, TWO NEEDED (part number MOC-2BM808A )
- 7 feet of stainless -8AN hose (part number AER-FBA0800)
Everything you need can be purchased through RacerPartWholesale--->
http://www.racerpartswholesale...lers2
WHEN ASSEMBLING THESE PARTS USE LIQUID GASKET SEALANT ON THE
THREADS DO NOT USE PIPE THREAD TAPE SH!T
. I recommend going to your
local Honda dealer and picking up a tube of Hondabond. Hondabond is legit to use
on coolant, engine oil, trannies, rear ends, your girlfriend, leaky Arby's cups, etc.
It's amazing stuff. The tape style thread sealer is too tough on the aluminum
components. It will mess up the threads and/or crack the aluminum. Ask me how
I know
PROPER HOSE ROUTING IS IMPORTANT!!!! LOOK!!!!
Bottom fitting to top of cooler, top fitting to bottom of cooler.
Here are some old photos of my oil cooler setup. No. The baller foglight brackets
are not for sale and are long gone. Sorry. I have not tried this setup on a
powersteering equiped corolla yet. You should only have to change out two of the
four required straight swivel -8AN fitting for 90-degree -8AN swivel fittings instead.
I have not tried this though. Don't yell at me if it doesn't fit your PS/AC 4AGE.
PROPER OIL COOLER MOUNTING IS IMPORTANT AS WELL!!!!!!!
You need to mount the oil cooler in such a fashion that if a bubble were trapped
in it, the bubble could escape upwards.
GOOD---->
GOOD--->
MAKES BABY JESUS SAD ---->
<br /><br />
Modified by HASportAE86 at 11:30 PM 2/3/2011<br /><br />
Modified by HASportAE86 at 11:32 PM 2/3/2011<br /><br />
Modified by HASportAE86 at 11:34 PM 2/3/2011<br /><br />
Modified by jondee86 at 5:50 AM 3/10/2011
Modified by HASportAE86 at 3:15 PM 2/7/2012
Email/Paypal "heyvanilladan@hotmail.com"
SwangBiz Chassis Products
http://forums.club4ag.com/zero...age=1
MFactory Longer T50 5th Gear Group Buy
http://forums.club4ag.com/zerothread?id=113077
Loud Pipes Save Lives -Swangbiz
Honda Master Technician/ASE Master Technician
kul_blu_car
2894 posts [98%]
 Re: DIY Parts List: Full Flow Aftermarket Oil Cooler (HASportAE86) » Reply  Edit
^^^Very nice writeup man!^^^
Fast, Reliable, Cheap. You can only choose two. Why?
Fast and Reliable = Not cheap
Reliable and Cheap = Not fast
Fast and Cheap = Not Reliable
rongfk
1296 posts [97%]
SO.CAL. LWD ca
cool
want OE power windows in your ae86?
want to convert your turn signal switch to opperate your jdm kouki signals properly?
want an adaptor harness, or sensors for you jdm digital cluster?
want a 9k tach to modify your stock zeinki GTS cluster?
HIT ME UP...... if i dont already have it, i can get it.
rongfk1963@yahoo.com
some helpfull info for you.....
AE86 Manual (100Mb) http://files.aeu86.org/manuals/AE86Manual.pdf
A4-GE Manual (92Mb) http://files.aeu86.org/manuals/4A-GEManual.pdf
GtsTone23
3595 posts [99%]
Chicago IllaNoise
Thanks Dan for the part numbers and for ANOTHER great write-up. Great asset to the community!!
"Behind every Successful Man lies a Pack of HATERS,
If they aint Hating Now, They'll be Hating Later"
~GtsTone23~
jballa1036
117 posts [100%]
Roswell Ga
Anybody have the original write-up as it has disappeared? lol
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
 Re: (jballa1036) » Reply  Edit
Quote, originally posted by jballa1036 »
I got the parts list at my house. Will edit tonight when I get home.
13133 posts [99%]
Portland
 Re: (HASportAE86) » Reply  Edit
Quote, originally posted by HASportAE86 »
jballa1036
117 posts [100%]
Roswell Ga
Thanks man I greatly appreciate it!!
87Coupe_de_Ville
"Creeper"
1555 posts [100%]
Socal 909/951 CA
can u please link me to these fittings i cant find it on the site.
1/2 to -8AN fittings, TWO NEEDED (part number AER-FCM2008)
Parts For Sale!
http://forums.club4ag.com/zerothread?id=106039
16v Timing Cover and 20v exhaust gasket
http://forums.club4ag.com/zerothread?id=112023
Project mu lugs
http://forums.club4ag.com/zerothread?id=113195
AE86 Seibon Carbon Fiber Hood
http://forums.club4ag.com/zerothread?id=113399
Flowisode_Zero
2784 posts [99%]
Glendale AZ
 Re: (87Coupe_de_Ville) » Reply  Edit
Quote, originally posted by 87Coupe_de_Ville »
Go to http://www.google.com and put in the part number. There are A LOT of distributors for Aeroquip parts.
Awesome DIY Hasport. Ive been saving up to piece together a setup for my 20V and this has been very helpful.
Why do noobs call their hatch a HATCHI, but no one calls their coupe a COUCHI?
shermayn jonson
1123 posts [99%]
Ca
I just did my oil cooler, god speed oil cooler relocation kit, anyway, id never touched a car in my life, put the kit together, mounted everything, then what happens, oil started drizzling out of the threads, oops forgot 2 seal'em, a pain just redoing the lines, i used some of that high tempeture tape, and fitted an O-rind 2 make sure, this SHiiit wasnt going 2 leak ever again, ran the car just testing it out for a couple months not DD or tracking the car, my oil line blows out from the A/N fitting oil everywhere long story short, the tape does work, but probly not as well as thread sealer lol, many mistakes where made during my project, also i would recomend using the same stuff on your brake lines i had tha sutff leak everywhere...nice write up
Music thread, post, listen, or die!!!!!
http://forums.club4ag.com/zero...34
SR5 only thread post pics!!!
http://forums.club4ag.com/zerothread?id=80539
GRAFF thread please post picks!!!
http://forums.club4ag.com/zerothread?id=76764
pholife
3691 posts [100%]
Laguna Beach CA
 Re: DIY Parts List: Full Flow Aftermarket Oil Cooler (shermayn jonson) » Reply  Edit
Excellent! Spot on! Selection of Mocal adaptor is awesome!
not to take away from Mr.D's post, I ran the lines similar to oem way so I added some line separator too
http://www.anplumbing.com/shop...ators
In addition, because my line hanged down a bit close to the ground, I added these to the hose to protect and to also keep it protected from my headers...
flameguard...
good stuff Mr. D! thank you
http://www.torparts.com
The WORLD Leader in OEM+Plus Reproduction Parts.
Get on facebook...torparts corollla for updates and discounts.
87Coupe_de_Ville
"Creeper"
1555 posts [100%]
Socal 909/951 CA
can anyone verify if this setrab oil cooler core http://www.racerpartswholesale...lers2 (SET-A13F22-8) will work in place of the mocal core?
Parts For Sale!
Project mu lugs
jspexae102
1141 posts [91%]
Union City CA
great thread, thanks!
Memoryfab.com
M-F 10A - 6P PST
Sat by appt. only
510.489.5866
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
yes. Just be sure to get the -8AN size version
negrizio
304 posts [99%]
Miami FL
Very nice thread!!!!!!!!!!!!!!
http://www.plagaperformance.com
1985 GT-S 3 Door Hatchback NA High Comp (In progres)
1968 230s Fintail Mercedes Benz
blkside
45 posts [100%]
Lake Elsinore CA
I have a full hydraulic shop at work so all I need is the adapter plate and cooler. Great write up and this will be one of my first longevity mods while I plan my build... Im gonna keep her running until I accumulate enough parts to warrant the rebuild...
Eric'sFreeAE86
2589 posts [100%]
Chattanooga TN
 Re: (blkside) » Reply  Edit
The kit I'm working with comes with -10AN fittings. Is there an advantage to using the smaller -8 or larger -10? I am at least familiar with the physics, larger diameter means lower pressure with a greater flow capacity, right? Will oil pressure be insufficient, or will the larger hoses just be a low pressure zone and pressure will go back up when it hits the smaller channels in the block?
In short, -10AN fittings cool?
13133 posts [99%]
Portland
 Re: (Eric'sFreeAE86) » Reply  Edit
Quote, originally posted by Eric’sFreeAE86 »
yes -10 can be used, but fitting the -8 is easier
redking
323 posts [100%]
Manila
pardon me if this might seem to you as a noobie question but..
why did you use 13 row instead of, say something like 19 row oil cooler.
My wallet is like an Onion. When I open it, It makes me wanna cry.
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
 Re: (redking) » Reply  Edit
Quote, originally posted by redking »
personal preference, 19row is fine too.
redking
323 posts [100%]
Manila
so basically a 13 row and 19 row will get the job done regardless of the amount of driving done or engine mods?
ToeKnee805
613 posts [90%]
Santa Paula California
QUick newbie question..
What did you use to cap off where the stock lines come out of the Oil Pan, and Under the Oil Filter?
1986 Corolla GT-S
1989 240SX Hatch
http://www.facebook.com/805LIDE
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
 Re: (ToeKnee805) » Reply  Edit
Quote, originally posted by ToeKnee805 »
20v's dont have dat.
I know for the oil pan you can just use another drain plug w/ crush washer, for the OEM sandwich plate I would have to look at it again, been a long time since I've played w/ 16v lol
13133 posts [99%]
Portland
Dan (HASport86) has covered the pan (pardon the pun of sorts ) Concerning the adapter, if you use the Mocal T-Stat version, you remove the original adapter completely and that removes the other fitting
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
 Re: (oldeskewltoy) » Reply  Edit
OST with the assist
ToeKnee805
613 posts [90%]
Spank you guys very much!
Great writeup by the way
1986 Corolla GT-S
1989 240SX Hatch
legit01rolla
222 posts [100%]
San Jose Ca
GREAT WRITE UP! 10+...im definitely going to do this.. but any suggestions on how to make that sick ass mount for the oil cooler HASportAE86?
87Coupe_de_Ville
"Creeper"
1555 posts [100%]
Socal 909/951 CA
Okay I have all these parts ready to go. I have one question. If I were to want to install oil temp/press gauges what would be the best way to do that since the mocal t-plate does not have fittings to do so? Any one that can help?
Parts For Sale!
Project mu lugs
HASportAE86
IE Gutter Trash
4096 posts [84%]
Loma Linda CA
use the stock oil pressure port on the exhaust side of the block, where the oem sensor used to go
 First  1 2 >  Last
» Return to General Technical Discussions
