 tranny issues
rooster
52 posts [98%]
solvay newyork
 tranny issues Reply  Edit
when i get it over 4000 rpm in first gear the tranny doesnt want 2 go into 2nd gear do i need new synchro
Randomist
259 posts [98%]
MT MEE QLD
 Re: tranny issues (rooster) » Reply  Edit
sounds like it, but a gearbox rebuild will be costly unless you can DIY
its a common mr2 gremlin in the c50 gearbox, is that the one you have? or do you have the late model c52?
AW 11 - the original and the best
rooster
52 posts [98%]
solvay newyork
 Re: tranny issues (Randomist) » Reply  Edit
im not sure which model i have ... where would i find that info @?
muffinman
4 posts [100%]
Fort Lauderdale Fl
85-86 came with the C-50. 87-89 had the C-52.
The C-52 has starter mounting positions on both the intake and exhaust side which look like ears.
rooster
52 posts [98%]
solvay newyork
 Re: (muffinman) » Reply  Edit
mine is an 86 but its got a remanufactured engine an tranny ill look ty
Randomist
259 posts [98%]
MT MEE QLD
 Re: (rooster) » Reply  Edit
id say you most likely have the c50, as they are pretty notorious for 1st to 2nd fork failure, and it was one of the main things toyota upgraded with the c52 to prevent it from occuring
i mean, its gonna cost alot to rebuild maybe see if any wreckers have a c52 mr2, late model gearbox you could take, if you get the one with the 2 starter motor positions its should be a c52
then just get a mechanic to check its working and swap her over
will save you alot of money on labour, and probably on parts too, as its cheaper to buy a whole second hand gearbox
