 DIY-20v valve seal replacement. step-by-step instructions
morgan
6446 posts [93%]
 DIY-20v valve seal replacement. step-by-step instructions Reply  Edit
this is done on a silvertop 20v. generally, the steps are very similar, just some things change. please refer to your fsm if its a different motor. i can say that the 16v is very similar, just the cam gears dont have the center marks to line up against each other, and the bolt loosening/tightening sequence might be different, i didnt check.
THIS IS A GENERAL, STEP-BY-STEP GUIDE ON HOW TO CHANGE YOUR SEALS
-gather all needed tools for the job. you dont want to be searching once you start.
-start with unbolting the negative terminal on your battery.
-next, remove the cam gear covers(top and middle) and the spark plug cover.
-remove spark plug wires and loosen plugs.
-heres the seals i used. 2 sets from an '03 toyota echo made by Fel-Pro. $54 each at pepboys, i got to love the discount i got, $20 each!
-how to properly line up the 20v cam gears and crank before removing anything.
-removal of the cam caps.
-then remove the cams. you dont need to remove the dist to get the exhaust side out, dont bother, you wont have to set the timing again then.
-removing shims and lifters/buckets.
-now, if you have the head on the motor, you need to keep the valves from dropping into the cylinder when you remove the retainers. i took a compression tester, removed the gauge and fitted a hose coupling, and removed the shrader valve from the other end. screw the compression tester into where the spark plug goes(after removing plug), and connect to compressor. 90psi seemed to be plenty to keep the valves up. some people use rope, and feed it thru the plug hole into the cylinder, or if the head is off, use the SST C-clamp.
heres the compression tester and the piece to connect to the compressor
heres the tool done, just remove the Shrader valve where the tweezers are pointing to.
-removing the retainers. be careful, they are easily lost.
-remove your old, leaking valve seals.
-everything apart and neatly organized.
-why not check if you can?
-the tool i made to put the valve seals in. this worked great! looks like a shell casing...
-installing the seal.
-then put the spring and top hat back in. followed by the retainers. i found that it you dipped the little retainers into some fresh oil, then tried, they would stick to the valves. this step is super frustrating the first few you do, it gets easier after about 18...
-re-installing the cams, then the cam caps. do this properly, as per FSM. try to keep the notches/marks lined up so you dont have to turn the cams once bolted down.
-install the new valve cover. best to replace the gaskets now too. dont want to be leaking oil afterwards.
-line up the cam gears wiht crank, and put the timing belt back on.
-put all covers and what not back and start her up. if you didnt remove the dist, timing should be fine.
Modified by cmorganae86 at 12:06 PM 10/28/2010
my 20v in an 86 swap guide
my mess of an 86...
*east coast toyotas forum*
13133 posts [99%]
Portland
very nice! I have valve seal removing pliers built for me about 20 years ago.
You can install the new seal in a 20V just with hand pressure? It has been my experience 16V seals require gently taps with a hammer
morgan
6446 posts [93%]
 Re: (oldeskewltoy) » Reply  Edit
thanks Dan, i was thinking i should have made something better than the single hook tool. the sealsy went in pretty easily, but i wanted pressure to be even all around the metal housing of the seal, so i figured why not turn down a tool quick at work.
my mess of an 86...
13133 posts [99%]
Portland
Quote, originally posted by oldeskewltoy »
Quote, originally posted by cmorganae86 »
similar tool for installation, and as you can see... simple homemade seal "pliers"
morgan
6446 posts [93%]
nice, that looks like it would be 10x easier than what i did. the hook sounded like a good idea, til i started doing it and wished i had another 1 or 2 hooks.
my mess of an 86...
ronny
RnD Office - Ronny
7077 posts [89%]
Irvine CA
 Re: (cmorganae86) » Reply  Edit
awsome thread!
VOLK TE37 only....!
project plan- 86 TWINKIES - has Begun..
Basketweaving M-F 7pm plz contact superstarlevin for enrollment
:thumbup:
morgan
6446 posts [93%]
 Re: (ronny) » Reply  Edit
thanks Ron.
my mess of an 86...
Mass20v
115 posts [97%]
TitleTown MA
Sweet, I'm actually doing this right now.. Very informative and clears up a lot that the manual leaves out. Thanks man!
Sam_Q
579 posts [99%]
Australia vic
I don't see the point of any special tools at all, I used some long/needle nose pliers to take them out and just my finger to push them back on. Has worked for a long time now.
s-86.com
morgan
6446 posts [93%]
 Re: (Sam_Q) » Reply  Edit
the needle nose i have grabbed the valve stem before the seal. i didnt know how much room i would have for fingers since i never did them before. better to have everything covered than be stuck if you ask me. rather be prepared than wing it. thanks for the heads up tho...
my mess of an 86...
supra_750
325 posts [100%]
Victoria texas
freakin AWESOME great write up
MY fully built 20v n/a build thread:
http://forums.club4ag.com/zerothread?id=74394
http://www.facebook.com/supra750
morgan
6446 posts [93%]
 Re: (supra_750) » Reply  Edit
thanks you sir, glad to see some appreciation.
my mess of an 86...
xtux
21 posts [100%]
Manila NCR
very informative. nice thread
Nusdogg
18 posts [100%]
St. Paul MN
Nice DIY. Thanks.
**1994 Honda Accord EX**
- JDM H22A/JDM F20B T2T4 LSD 5spd trans
(200whp/156wtq) :D
**1995 Geo Prizm LSi**
-USDM 7AFE(1.8L) Auto
-Maybe a 4AGE swap?
wrenchdad
339 posts [100%]
Natchez MS
 Re: (morgan) » Reply  Edit
Guys,
Here is another writeup I found, it was done some time ago, but it does show a great tool for doing the retainers. I haven't gotten one yet but next seal job I will for sure, it would have saved me HOURS doing my last seal replacement.
http://www.aeu86.org/index/eng...75407
Here is a link to the tool listed in the first picture
http://buy1.snapon.com/catalog...=1578
Seems worth the $40 to me!
later wd
" Second place is just the first loser" the late Dale Earnhardt
elmerkit
351 posts [100%]
carson la
Great information thanks for sharing.
"On sale Itp tires and ATV tires"
RaceRV
280 posts [100%]
Haiku Hawaii
 Re: » Reply  Edit
great fix for a smokey 86 !! thanks 4 the share..
karate_crimson
8227 posts [89%]
Southern CA
 Re: Re: (RaceRV) » Reply  Edit
Righteous Craig. I am about to do this soon. Not much for doing things that deal with the inner workings of the engine, but this write-up is exactly what I was looknig for!
superpilun
211 posts [100%]
 Re: Re: (karate_crimson) » Reply  Edit
Excellent write-up. FYI, http://www.toyotool.com/ makes a tool to make the removal and installation of valve springs, retainers, keepers, with one push. I worked with the owner to have one made that fits the smaller bucket openings in the 20v. It's very worth it.
http://img.photobucket.com/alb...1.jpg
Pilun
Product Design Engineer
Grant
3656 posts [86%]
San Jose ca
O nice! I was wondering why they supported such a small valve stem.
I ended up buying the Lisle cheap version and turned the tool down with the help of a friend on a lathe to make it small enough.
Stand Alone ECU tuning. Message me for details.
Looking to buy a corolla manual rack and a TRD 3 gear transmission.
*also wtb 4 point roll cage/bar for ae86 coupe
Sam_Q
579 posts [99%]
Australia vic
 Re: (Grant) » Reply  Edit
why what's so small? the seals?
s-86.com
morgan
6446 posts [93%]
im guessing the shims, especially compared to the 16v shims.
my mess of an 86...
ae86sleeper
9 posts [100%]
mobile Al
where is the first piston (closest to the cam) suppost to be when at T.D.C.?
i just did this and the car wont crank...so i thing the timing is off... PLZZ HELP!!!
wrenchdad
339 posts [100%]
Natchez MS
 Re: (ae86sleeper) » Reply  Edit
with the crank timing gear on its mark( its a small notch in the outer edge of the crank gear), lined up with the one on the oil pump case, that should put the number one piston, the one closest to the timing belt, at TDC, then the two cam timing gears should have two marks pointing at each other, like 3 o'clock for the intake and 9 o'clock for the exhaust also there are two marks at the 12 o'clock position for both gears that line up with marks on the back plate behind the cam gears, there is a 5th mark that you can see thru the oil filler cap, its a small indention, like a drill divet, in the intake cam that lines up with the edge of the baffle just under the filler cap.
hope this makes sense,
later wd
