Rue
993 posts [99%]
FTW TX
| Re: My Corolla (HondaRue) » | 5:36 PM 11/16/2010 |
Reply
Edit
A few year I picked up a GTS donor
Cleaned engine bay
And finished conversion
85 GTSr5 Hatch 3sge BEAMS ITB Powered!!! http://forums.club4ag.com/zero...age=186 Cressida Original 5-speed (Daily) => 1uzfe http://jzxproject.com/bbs/index.php?showtopic=7121 WTB: Grey on Grey Zenki Sr5 Door Panels!!! SELL THEM TO ME!!!
Rue
993 posts [99%]
FTW TX
| Re: My Corolla (HondaRue) » | 5:41 PM 11/16/2010 |
Reply
Edit
A local JDM importer got in a complete Levin front end and rear bumper and for a SUPER LOW price it was mine!
Rue
993 posts [99%]
FTW TX
| Re: My Corolla (HondaRue) » | 5:47 PM 11/16/2010 |
Reply
Edit
Digi Cluster
W58 with 2S bell housing
And shifter location with auto AE86 crossmember
Jeonsah
1814 posts [95%]
Co
im lovin it!
WTB AE86 Best Motoring International Vol. 42. Pm if you have it!
Rue
993 posts [99%]
FTW TX
| Re: My Corolla (HondaRue) » | 5:56 PM 11/16/2010 |
Reply
Edit
20v BT ITBs with adapter manifold for BT BEAMS from CelicaRA45
And the past weeks excitement.... a BRAND NEW BEAMS MOTOR!!!
Rue
993 posts [99%]
FTW TX
| Re: My Corolla (HondaRue) » | 6:07 PM 11/16/2010 |
Reply
Edit
And going to paint the engine bay before the engine goes inBefore:
Cleaned and sanded:
And painted:
A few more pics...
timchan1975
65 posts [100%]
honolulu hi
nice! liking the BEAMS keep it up!!!tim
i13ethat
457 posts [100%]
SoCaL ca
nice work there. looking good
[Socal] -JDM Toyota Celica Tiger Stripe Front Seats- [for sale] http://forums.club4ag.com/zerothread?id=110842
daytona350z
539 posts [99%]
| Re: My Corolla (HondaRue) » | 7:25 AM 11/17/2010 |
Reply
Edit
very nice!!Curious if you are gonna relocate the starter on the 2s bellhousing. The beams head has that oil drain that may get in the way. also, what computer are you going to be running?
Rue
993 posts [99%]
FTW TX
| Re: My Corolla (daytona350z) » | 3:47 PM 11/17/2010 |
Reply
Edit
Nope... not planning on relocating the starter. I'm getting ready to machine a new plate that goes between the engine and transmission that will match the 2s bell housing and starter location.And for the ecu I'm going with an Adaptronics e420c. It's one of the only ones I could find to control the dual vvti. I just ordered a flywheel and clutch so hopefully I can get the engine and tranny put together and get the engine mount brackets/subframe modified.
daytona350z
539 posts [99%]
| Re: My Corolla (HondaRue) » | 5:03 PM 11/17/2010 |
Reply
Edit
very cool. im tempted to do the same swap, but am reading up all the info i can. Any reason you didnt want the 6 speed?
Rue
993 posts [99%]
FTW TX
| Re: My Corolla (daytona350z) » | 5:29 PM 11/17/2010 |
Reply
Edit
Yea... I refuse to butcher my transmission tunnel. I like making swaps look as stock as possible.
daytona350z
539 posts [99%]
| Re: My Corolla (HondaRue) » | 6:28 PM 11/17/2010 |
Reply
Edit
| Quote, originally posted by HondaRue » | | Yea... I refuse to butcher my transmission tunnel. I like making swaps look as stock as possible. |
me too! i wish there was a way to fit it without messing up the tunnel, heard if you lower the x member by about 1" it "should" fit. interested to see your adapter plate for the starter. maybe you fab up 2 ?
Rue
993 posts [99%]
FTW TX
| Re: My Corolla (daytona350z) » | 7:33 PM 11/17/2010 |
Reply
Edit
I'm spacing my subframe down 1.125". I machined my own subframe spacers. Here's a pic:
And a pic of my refurb strut tubes and the nrca's I machined for myself because I'm a cheap-ass and hate spending money on parts I can make myself.
daytona350z
539 posts [99%]
| Re: My Corolla (HondaRue) » | 11:43 PM 11/17/2010 |
Reply
Edit
so cool, cant wait till you get that motor in and fired up!btw, do you need the subframe spacers because of the engine cover height?
Rue
993 posts [99%]
FTW TX
| Re: My Corolla (daytona350z) » | 1:44 AM 11/18/2010 |
Reply
Edit
From what I've seen so far the engine height is a factor. Mounting it high enough to have clearance between the oil pan and the subframe/steering rack sets both the engine and transmission too high to clear the hood and firewall/tunnel.I just picked the engine up last Thursday and I'm waiting on my clutch and flywheel to come in before I set everything under the hood to confirm everything above. It'll probably be a couple of weeks before I get to make the plate between the engine and tranny so as much as I want to get this thing in it'll most likely be a few weeks.
daytona350z
539 posts [99%]
| Re: My Corolla (HondaRue) » | 7:28 AM 11/18/2010 |
Reply
Edit
| Quote, originally posted by HondaRue » | | From what I've seen so far the engine height is a factor. Mounting it high enough to have clearance between the oil pan and the subframe/steering rack sets both the engine and transmission too high to clear the hood and firewall/tunnel. I just picked the engine up last Thursday and I'm waiting on my clutch and flywheel to come in before I set everything under the hood to confirm everything above. It'll probably be a couple of weeks before I get to make the plate between the engine and tranny so as much as I want to get this thing in it'll most likely be a few weeks. |
yep, thats what i have been looking into as well from seeing all the beams swaps over in NZ. Also, i hear that you have to trim some of the oil pan webbing to clear the steering rack as well. are you using a clutch and flywheel for a sxe10 (rs200) or a std clutch and flywheel from an mr2? im not sure if i am being a pest here askin you all these questions, so i apologize in advance for that.
Rue
993 posts [99%]
FTW TX
| Re: My Corolla (daytona350z) » | 3:44 PM 11/18/2010 |
Reply
Edit
You're not being a pest... your mention of the oil pan trimming means you've been looking at Bill Sherwood's swap pics. I'm not planning to do that to mine. Just from looking at his pics it looks like he only spaced his subframe .500" or so and chose to shave the oil pan and mount the engine closer to the crossmember.Again I'll find out more when I get the engine into my car and start trying to get the mount brackets made. I bought an aftermarket flywheel and clutch for an MR2 turbo and I'm still not sure how everything is going to work out.
mrfuzzy
1513 posts [100%]
Did you turn it off and back on
Does the 2s bell bolt up do you have to make the plate?
Learn It To Earn It! Garage.SoCal86.com ~>SoCal86.com<~ ->KSDEngineering.com<-
Pho King
235 posts [100%]
Anaheim CA
Make me a subframe/engine/transmission mount kit too....... I would so buy it. I'm a BEAMS swap fanboy, haha. Looking good so far in your thread!!!
Rue
993 posts [99%]
FTW TX
| Quote, originally posted by mrfuzzy » | | Does the 2s bell bolt up do you have to make the plate? |
Yes... it bolts straight up. I'm only making the cover plate that goes behind the flywheel to match the 2s bell housing to the beams motor so it will look like it came that way.
85levin
838 posts [97%]
san jose CA
looking good Aaron, keep it up. i like your attention to detail.
black top part out with many aftermarket parts http://forums.club4ag.com/zero...82595 complete black top and aftermarket suspension parts... http://forums.club4ag.com/zerothread?id=100376
Rue
993 posts [99%]
FTW TX
| Quote, originally posted by 85levin » | | looking good Aaron, keep it up. i like your attention to detail. |
Thank you, Sir. I have to say I was surprised when your front end parts went up for sale. And on to today's progress...
85levin
838 posts [97%]
san jose CA
yes, i did not get rid of the car just weight reduction and new engine swap. i am headed to california tomorrow though, not sure when i will finish. good luck with your project bro.
terolla
231 posts [100%]
new york n.y.
hondarue, look up the link ecu (its what im gonna use) , it runs the dual vvti and they have a start up download (to get the engine running) for the blacktop beams nice work
Jeonsah
1814 posts [95%]
Co
bay came out nice. Only prob is that white is gonna make everything look dirty. So now your gonna wanna clean everything haha.
Rue
993 posts [99%]
FTW TX
| Quote, originally posted by Jeonsah » | | bay came out nice. Only prob is that white is gonna make everything look dirty. So now your gonna wanna clean everything haha. |
Yea... but my car is white. And keep in mind I make it a point to make my swaps look as original as possible.
Cressida
6 posts [100%]
Fort Worth TX
Looking really good, I was wondering what you were talking about before but the pictures really clear things up.I had a couple questions now that I've seen it all though: Your header will probably be custom-made. Are you going to make a piece that will allow you to connect it to any exhaust made for the Corolla? You decided to ditch A/C, does that mean you're going to get rid of any other amenities too? Are you going to run a full interior? Are you going to have to run a tach adaptor to allow the RPMs to display on your Digi Cluster? Sorry if you've already covered this, I have a piss poor memory. I'll think of more later I'm sure.
mrfuzzy
1513 posts [100%]
Looks perdy
| First 1 2 3 4 5 > Last |
