 My CorollaFirst  < 11 12 13 14 15 >  Last
Turtle
2681 posts [98%]
 Re: (Rue) » Reply  Edit
The muffler just... fell apart? like the welds gave up and it fell to pieces?
R
The Adventures of TURTLE and LOLA the CoLola Updated: 06/28/2011
LOLA, The Freshmaker
Turtle's HELLA CHMSLs
Lola's Off the Crank: A Window's Rise to Power
Turtle vs. the W-58
4doors
41 posts [100%]
Aledo TX
done asploded. could have had something to do with the awesome backfires blowing the welds and causing danger to manifold.
Rue
993 posts [99%]
FTW TX
 Re: (4doors) » Reply  Edit
Problem:
Solution:
85 GTSr5 Hatch 3sge BEAMS ITB Powered!!! http://forums.club4ag.com/zero...age=1
86 Cressida Original 5-speed (Daily) => 1uzfe http://jzxproject.com/bbs/index.php?showtopic=7121
WTB: Grey on Grey Zenki Sr5 Door Panels!!! SELL THEM TO ME!!!
joel23
185 posts [100%]
new muffler looks good.......
4doors
41 posts [100%]
Aledo TX
hks wins it. gotta hear how this sounds with open stacks and new muffler.
saliegh
2 posts [100%]
Cape Town
 Re: fabricating an adaptor for the itb's » Reply  Edit
hi there
i would like to know how you fabricated the adaptor to fit the ITB's. im currently busy with the same setup but struggling to get the adaptor.
thanks
celicaRA45
159 posts [99%]
melbourne victoria
he bought 1 of me to do his set up glenn
gbooth@bigpond.net.au
saliegh
2 posts [100%]
Cape Town
 Re: (celicaRA45) » Reply  Edit
Ohk I have the designs for an adaptor, going to the guys who does fabrication. Will have the adaptor in a day or 2. What are the power figures for a beams running ITB's?
Rue
993 posts [99%]
FTW TX
 Re: (saliegh) » Reply  Edit
Not much going on with my corolla right now. Working on my 1uz Cressida project as much as possible. Bought Marlin Crawler shifter bushing and the BillyM brass shift bushing as recomended by Assassin10000. Brass bushing will be here on Thursday.
Old...
New...
EvoSolley
94 posts [100%]
Louisville Ky
I bought t3 shifter busing as one of the first mods to my ae86. Best investment so far haha. Cars looking good! keep it up
4doors
41 posts [100%]
Aledo TX
did you get your clutch sorted out for Sunday? i eventually got the new subframe in and the bay degreased in my car.
Rue
993 posts [99%]
FTW TX
And the BillyM shifter bushing that goes in the striker arm...
Chindiesel
94 posts [99%]
Pembroke Pines fl
Where did you get the RA45 adapter? I have the motor in a AE71 and need to use the ITB's instead of the single throttle body.
Drive a Toyota....the only way to fly
http://WWW.Chindiesel.com
Rue
993 posts [99%]
FTW TX
 Re: (Chindiesel) » Reply  Edit
Quote, originally posted by Chindiesel »
Quote, originally posted by celicaRA45 »
celicaRA45
159 posts [99%]
melbourne victoria
http://forums.club4ag.com/zerothread?id=109583
Rue
993 posts [99%]
FTW TX
Been a while since I've posted an update. Currently having clutch trouble. Not even 4,000 miles on it yet and I'm already having problems. Has something to do with the pressure plate. Pulling the tranny tonight so we'll see what I find.
Any recommendations on a clutch brand???
UltimX
496 posts [98%]
ba ca
Comp clutch if they make it for the engine
celicaRA45
159 posts [99%]
melbourne victoria
if you are using the supra box i put the imput bearing into the back of the crank can buy a 16mm single race 1 and that might help also on the supra boxes w55/57/58 i use 1 litre of dextrin 3 auto trans and 1 litre of 75w gear oil
and you could also be over clutching on your pedal ratio
might need to put a stop under the clutch pedal
these are the things i did to make the gear changing better
also if you are using a aftermarket pressure plate get them to beef up the straps on the side of the pressure plate
the altezza pressure plate is pretty good as std ,but we beef them up to stop them snapping
Modified by celicaRA45 at 3:49 PM 10/20/2012
Rue
993 posts [99%]
FTW TX
Well... pulled he clutch and found................................. nothing. Clutch and pressure plate look like they have about 4000 miles on them. I'm replacing the stamped steel clutch fork with a cast one and I bought a 3/4" bore clutch master cylinder. I don't think the clutch fork is the problem but I'm hoping the new master cylinder fixes the problem. We'll see.
Currently staying super busy with the 1uz cressida project. Need clutch lines and clutch kit before I can set the v8 in the engine bay. Going 5-lug, big brakes, big wheels... gonna be fun
Rue
993 posts [99%]
FTW TX
Clutch fork was a failure... supra clutch for is too short.
But 3/4" bore clutch master cylinder solved my problem. Got everything finished last night and it feels great.
LongGrain
516 posts [94%]
Green Bay WI
great build, would you ever consider duplicating any of the machined parts you made? mainly exhaust flange? if so I'd buy one.
i like how this build turned out, gave me a lot of ideas for my swap.
Dark*Squad!
Rue
993 posts [99%]
FTW TX
 Re: (LongGrain) » Reply  Edit
I was told by a local shop after I made my flange that I could've just bought one. Said it was a part they carried. I'll contact them to confirm and see if I can get some details.
LongGrain
516 posts [94%]
Green Bay WI
that would be awesome, I'd appreciate any info that you have!
Dark*Squad!
4doors
41 posts [100%]
Aledo TX
updates!
Rue
993 posts [99%]
FTW TX
Like?????
Nothing really to update. Using my corolla as a daily until I can get the cressida finished. It's running super rich which is driving me nuts. Planning to switch back to the 4.3 final drive. Clutch is feeling great.
Hoping between getting a tune and the ring and pinion swap I'll be happy with it. If not, I'll be looking at cams and valve train. Really want to get paint and body work done soon.
LongGrain
516 posts [94%]
Green Bay WI
what length stacks did you get? I'm thinking about upgrading from my T3 stacks as well since I'm also not all that happy with the fitment.
also any updates on where to buy a header flange?
Dark*Squad!
Rue
993 posts [99%]
FTW TX
I believe the stacks are 70mm. And the shop with the exhaust flange is Alamo Autosports... http://www.alamoautosports.com/
I contacted them and they said they were out of stock on the flanges and hadn't received any orders to justify machining a batch of them.
celicaRA45
159 posts [99%]
melbourne victoria
making 145mm long curved ram tubes in fibre glass to suit black top throttles which work out to be the correct length of the std plenum
will post pics when he finishes these off also they can be turned so they will fit under bonnet
kirksekm
775 posts [100%]
YOKOSUKA KANAGAWA
hey bro can u please pm me ur email address again i need some more of the ncras made but this time with out the center boss u kno?
[b]"my car is so low... i have to travel to the other side of the world to do an oil change"[/b] :o
[b]"WHAT THE F*^K IS JUICE?... GIMME SOME OF DAT GRAPE DRINK BABY!!" [/b] :thumbup:
[b]"I'D RATHER PUSH MY TOYOTA THAN EVER DRIVE A HONDA"[/b] =)
[u][b]" 60 PERCENT OF THE TIME IT WORKS EVERY TIME-SEX PANTHER- BRIAN FANTANA" [/b];)[/u]
"カウンターステアが遅いんだな?" Keiichi Tsuchiya
Rue
993 posts [99%]
FTW TX
Got an idea... why don't you make a thread about all of the parts you make/sell and quit advertising in my build thread. You were a bit of an a$$ when I bought the first manifold from you due to a misunderstanding and I love reading your posts about how I did my swap wrong.
