 SoCal NEED HELP: Rear Suspension Top Mount Repair and Reinforced
Garage7RP
630 posts [100%]
Rosewood Ca
 SoCal NEED HELP: Rear Suspension Top Mount Repair and Reinforced Reply  Edit
Need help in repairing this and would also like to reinforce the other side so this won't happen again. I was trying to figure out where the rattling noise is coming from and this is where I found it...
I am willing to tow the car locally and would like an expert and experienced place that can handle such fabrication. Any help and guidance where to go is appreciated. Thank you.
Thanks!
Garage7RP@Hotmail.Com
http://www.ajps.com.au For all you AE86 and other old school toyota parts.
http://jrtdigitalgraphics.com/ Wrap IT and Protect IT!-By Jun Mendoza
For all your Vinyl Graphics and Clear-Bra needs go to JRT Digital Graphics.
zlidewayz
2193 posts [99%]
CenCal CA
 Re: SoCal NEED HELP: Rear Suspension Top Mount Repair and Reinforced (Garage7RP) » Reply  Edit
jsp pretty sure he can fabricate a new mount or weld a thick piece of steel on that area
"Living the ae86 life" ...what other way to enjoi driving then to drive zidewayz
Thumbs up to Eric at RhysMillenRacing
Also in need of super clean Driver and Passenger Fenders email me
BEST FORM OF CONTACT= zmanae86@yahoo.com
Garage7RP
630 posts [100%]
Rosewood Ca
I thought of JSP but I am in LA County but not far from Orange County.
Thanks!
pholife
3691 posts [100%]
Laguna Beach CA
 Re: (Garage7RP) » Reply  Edit
Speak to Louie at LCon Fabrication in Westminster.Garden Grove otherwise I would go to JSP....good luck
http://www.torparts.com
The WORLD Leader in OEM+Plus Reproduction Parts.
Get on facebook...torparts corollla for updates and discounts.
Garage7RP
630 posts [100%]
Rosewood Ca
I emailed Jimmy of WellBiltKustoms and also PMd him. I am hoping he respond so I will have an idea of the cost.
Thanks!
Garage7RP
630 posts [100%]
Rosewood Ca
I dropped of the car at Wellbiltkustoms today.
Thanks!
VitriumGTS
4730 posts [96%]
San Jose/San Diego CA
were you using a rear coilover setup? or a special uppermount ?
tchybrid
1088 posts [91%]
323
wow, i've never seen that happen before, it looks like he used a custom rear coilover set up, definitely looks like a shock and spring combo.
definitely get both sides reinforced if you want to run that type of coilover set up in the future.
Kenny
my 4th corolla revival
http://forums.club4ag.com/zerothread?id=85898
Garage7RP
630 posts [100%]
Rosewood Ca
It's not custom. It's D2 coilover suspensions for the AE86. I got it when it first came out.
Thanks!
tchybrid
1088 posts [91%]
323
Quote, originally posted by Garage7RP »
the D2 coilover set up is a single shock and spring, that puts way too much strain on 2 small points in the chassis. definitely reinforce the upper shock mount since you'll be repairing the damage.
Kenny
SaruMONKuraS
Don't miss it!!!
392 posts [100%]
K.P.T. Hawaii
Either you reinforce the chasis or change out your suspension. Honestly, I would reinforce the entire chasis. Ask why? These cars take a toll afterawhile driving them hard and/or lowered. Problem w/ repairing where it tore is that it is likely to tear again next to the weld. You can't help. That's what heat does.
I could see it being repaired and used for it's orginal purpose which was a "shock tower/mount" and not "weight supporting point". If you keep the suspension, then chop off the top of it where it ripped. Fabricate a box like top mount welded onto the body w/ a thick enough plates, and weld across left to right at least the minimal.
Post photos of the repair. A guy who use to work for me used to hang turns like nuts on his VW until one day there was a hair line crack from the firewall all the way to the front support just above the lower unirail. I ended up welding it straight through, but I told him his driving had to stop. LOL.
Every household needs a delicious can of bondo.
techno93@pacbell.net
59 posts [100%]
placentia ca
can anyone send me thelink to the jsp place? ill be getting coils soon and am very intrested in beefing up the rear shock towers
» Return to Paint, Body and Body Repairs.
