 Finally back on the road :-DFirst  < 5 6 7 8 9 >  Last
td-civ
10 posts [100%]
Brantford ont
this is a really sweet build alot of hard work in this car keep it up and 20v for the win
harris1
6 posts [100%]
new york texas
 Re: Finally back on the road :-D WITH PICS FROM THE NÜRBURGRING (Jan Pedersen) » Reply  Edit
yes you are excited about that man because you have rebuild your car and its looks nice to me also
thanks
__________________
Auto Monitor
TcChino5
22 posts [99%]
Tampa FL
sweet looking build
You only live once, enjoy it while it lasts :P
Czarnojan
38 posts [100%]
 Re: (Jan Pedersen) » Reply  Edit
hey great looking build, i hope mine can turn out just as well!
i was wondering how did you transport your car to get it sandblasted? did you have it on the rotisserie?
Sefmyster
8 posts [100%]
Ontario ca
 Re: Finally back on the road :-D (Jan Pedersen) » Reply  Edit
superb work
85levin
838 posts [97%]
san jose CA
 Re: Finally back on the road :-D » Reply  Edit
any update? do you have it tuned yet?
black top part out with many aftermarket parts
http://forums.club4ag.com/zero...82595
complete black top and aftermarket suspension parts...
http://forums.club4ag.com/zerothread?id=100376
dangina
461 posts [97%]
lethbridge ab
Build Thread!
http://forums.club4ag.com/zerothread?id=75666
Rejor
194 posts [100%]
jacksonville fl
 Re: (dangina) » Reply  Edit
Oh boy, here we go....
Rufio_86
222 posts [100%]
Santa Clarita CA
One of the best rebuild threads i have ever seen. You just didnt do the engine but you did the full frame.
I like the way how you properly paint the car(from stripping it, sandblasting, to even the underbody) Kudos to you and pops. Like someone else said too, you do have pleny of cool tools to do the FULL Rebuild.
Must feel nice to having a brand new AE86 in this time of age.
-Koa
"I'm a Lightweight DD"
My Garage
DD - 86' AE86 Red =)
Track - 92' R32 GTS-T ;)
Wifes Garage
03'AP1 GPW Hybrid 2.2L
Jan Pedersen
531 posts [100%]
Ok so I've been away for quite some time mostly due to working. But the engine is now up and running. I haven't been driving it since its winter but it'll be ready at spring. It still needs a few things: Brakes, MOT and a proper tune...
This tuesday we had our anniversary: The same AE86 for ten years
Thanks for the comments while I've been away BTW!
'86 Euro Levin Project
Jan Pedersen
531 posts [100%]
Oilpressure is now ok with the bigger hoses d:)b
The new radiator is mounted as is the plenum:
I need to shine up a filter box but the setup is working and it is very smooth and quiet.
It is more or less ready to be tuned on the dyno on monday d:)b
Grant
3656 posts [86%]
San Jose ca
Sorry I haven't had time to send you the tune. It's on my other computer.
What made you choose to use an air box?
Stand Alone ECU tuning. Message me for details.
Looking to buy a corolla manual rack and a TRD 3 gear transmission.
*also wtb 4 point roll cage/bar for ae86 coupe
Grant
3656 posts [86%]
San Jose ca
What size oil lines are you using now? And before?
Jan Pedersen
531 posts [100%]
 Re: (Grant) » Reply  Edit
I'm slightly dissapointed with the dyno result:
(The hand drawn one - the other is a 16V with 258/262 cams and ITBs)
This is with intake box and kat from a swiess AE86. I'm pretty sure one of these is restricting the flow since the curve is so flat at high rpms. I'll have to do some experiments on this
Grant: I need the car relativly quiet to drive the Nürburgring and the local trackdays
Jan Pedersen
531 posts [100%]
T3 adjustable bar
Testfitted my TE37s
But the Toyo R888 are too wide to fit under stock arches
So either I have to trim off 5 mm off each panel, drop the wheels or find some other tires...
Jan Pedersen
531 posts [100%]
New oil cooler:
Filter relocation kit:
And TE37s:
whitetropics
200 posts [100%]
houston tx
awesome color on the car , and great job restoring your old hatch
Jan Pedersen
531 posts [100%]
 Re: (whitetropics) » Reply  Edit
Thanks!
This is how I spend 86-day:
http://youtu.be/OgtWE1YLd5g
Unfortunately I had a bearing failure and only did this "warm up lap"
Jan Pedersen
531 posts [100%]
Thanks!
MazterDizazter
259 posts [100%]
Marshfield MA
Looking good!
1987 Toyota MR2 hardtop
20v blacktop 4A-GE
Ground control, Koni, Cusco, ST
XXR, Toyo, Wilwood, EBC, Odyssey
Recaro, MOMO, Fidanza, SPEC
Peabody
10 posts [100%]
Southern Florida
Wow great build. your hard work has really payed off!
Jan Pedersen
531 posts [100%]
A couple of friends and I just bought a Lexus IS/RS200 AZ6 gearbox each to fix the ratio isues of the T50.
The plan for now is to make an adaptor plate to fit between engine and gearbox or weld the T50 bellhouse to the AZ. The Leen kit looks great but is just way to expensive... To be continued
SCRAPE
84 posts [100%]
Las Vegas NV
Hi Jan,
I'm Jon,
Would you mind saying what degree your cams were set? Also the combustion specs for your engine. Looking at the (upper graph) the output is rising and falling quite a bit. This indicates that something other than flow is creating a restricting condition. I'm sure you figured this by now, but from one tuner to another I'd like to help if I can.
Some say nobody's perfect
Others will say practice makes perfect
If you want to know which one is right...race me.
.TRD.TRUENO.
7 posts [100%]
New York City NY
Awesome Job!! Ur 86 passion is soo inspirational, and love ur car man
Jan Pedersen
531 posts [100%]
 Re: (SCRAPE)... » Reply  Edit
Quote, originally posted by SCRAPE »
Hi Jan,
I'm Jon,
Hi Jon. The engine is a completely stock black top. I'm running my ignition like this:
I didn't do anything about it yet - I just enjoyed driving it last year
Jan Pedersen
531 posts [100%]
These pics where taken by Ebbe Sommerlund for a danish newspaper:
Hope you guys like the d:)b
ruiz913
152 posts [99%]
Neither Here Nor There NJ
Very nice. Excellent choice on the paint color. I think it looks great with the TE37s
Jan Pedersen
531 posts [100%]
 Re: (ruiz913) » Reply  Edit
Thanks!
I finally got around to start the next project: Six speed AE86
T50
Lexus IS200 AZ6
T50 clutch housing:
AZ6 clutch housing:
Final measuring...
...Before milling:
To be continued...
85levin
838 posts [97%]
san jose CA
that's a great upgrade. nice work!
Jan Pedersen
531 posts [100%]
 Re: (85levin) » Reply  Edit
Yeah I'm sure it will be awesome! And thanks!
Cutting the 10 mm plate was a ******:
Now we just need to have the parts welded:
To do:
Welding
Finding a clutch cylinder that will fit
Custom cross member
Custom drive shaft
Speedo drive
Mounting AZ6
Beat the h*** out of it
