 Megasquirt DIYPNP and AE101 GZEFirst  1 2 >  Last
nyabinghi
165 posts [100%]
 Megasquirt DIYPNP and AE101 GZE Reply  Edit
I'm planning to put a DIYPNP MS on my gze and I have some questions. I've already assembled a bosch 55pin DIYPNP for an OPEL engine so I know the product a little.
Does the N76 model is the one I need for my wiring ? In the reference section I can see the AE101 ECU has 3 connectors (16, 22 and 26pins) so I think the N76 is the good one, right ? http://www.diyautotune.com/diypnp/models.html
The microsquirt module doesn't have pots for adjusting the main VR signal, do you think it will be easy to get a good strong signal from the stock gze CAS ? Or may I have signal noises ?
I will connect the stock GZE coils to the MS, what kind of dwell value can I put for start ?
Thanks
Modified by nyabinghi at 7:46 AM 1/20/2011
Measure your car performances with PerfExpert Android and iOS app
nyabinghi
165 posts [100%]
 Re: Megasquirt DIYPNP and AE101 GZE (nyabinghi) » Reply  Edit
anyone ?
Russ
758 posts [100%]
Lawrenceville GA
Hello,
You'll want to look at your harness connectors vs. the N76 image. Be sure all the big / small metal terminals are in the same places. I think the issue with the 20V connector is one of the smaller pin count connectors (either the 16 or 22 pin) uses all fat pins, where the N76 connector has all small pins.
You should be OK for the GZE CAS. I'm running one right now on my N/A 16V and firing a wasted spark coil pack directly. If you do have noise (which I don't think you will), there is also an LM1815 VR conditioner on the main board. Run whichever signal (24 tooth or 1 tooth) is having the issues (viewed in composite logger) through the LM1815 circuit.
I don't have any personal experience with the GZE coils. I think we may have some here at the shop that I can test. If we do, I will put the oscilloscope on them and find the proper dwell for you.
-Russ
nyabinghi
165 posts [100%]
 Re: Megasquirt DIYPNP and AE101 GZE (Russ) » Reply  Edit
Thank you Russ, I would appreciate that!
nyabinghi
165 posts [100%]
I looked at the pins on my ECU. It seems that all connectors and pins are OK with the picture!
Russ
758 posts [100%]
Lawrenceville GA
I can't find the coils we have here. I know they're somewhere. I'll have to ask a few of the other guys if they know where they went.
nyabinghi
165 posts [100%]
Usually I use 2 BIP373 ignition modules that directly controls coils, but now I wonder if I can make the MS directly control the stock GZE igniter. This will prevent me from doing any wiring, just plug the DIYPNP in place of the stock ECU and go!
Where can I find some doc on how the stock ECU manage the igniter (voltage etc...) on this engine ?
Thanks
Russ
758 posts [100%]
Lawrenceville GA
Yep, the multiplexing igniter has recently received MS2Extra support. Be sure you're using the latest MS2Extra release firmware. Choose "toothed wheel" from your input menu and setup the toothed wheels appropriately. Next from your "more ignition" menu you'll want to turn "Toyota DLI" to "on".
Mikealike
356 posts [100%]
Jacksonville Fl
i would like to make an adapter harness for my 20 valve ST so my question is where do i get the plugs that are pictured with pins?
Performance Unlimitied
Luzunaris99@gmail.com
Russ
758 posts [100%]
Lawrenceville GA
 Re: Megasquirt DIYPNP and AE101 GZE (Mikealike) » Reply  Edit
Here's the break-out-box with the connector pictured above:
http://www.diyautotune.com/cat....html
*** Look and be sure it's the right connector. Be sure all the large and small pins are in the same places too.
nyabinghi
165 posts [100%]
Quote, originally posted by Russ »
Thank you very much for this info.
What about the ISCV ? Do you know what kind of Idle controler we have on the AE101 GZE ? PWM valve ? Stepper motor ? Thanks
I have my DIYPNP at home but not assembled yet...
Russ
758 posts [100%]
Lawrenceville GA
How many wires does your idle valve have? I haven't seen a stepper on a Toyota in a while, but I'm guessing yours has a 3-wire PWM.
The two recent DIYPNP main board revisions (1.5 and 1.5B) have the circuitry included to build the 3-wire PWM valve driver.
http://www.diyautotune.com/diy...ntrol
nyabinghi
165 posts [100%]
Ok, I think I've got the last revision board as I ordered it in December.
Will check the ISCV plug on the car, but according to these wiring diagrams, there are no electric wire for the ISCV...
Russ
758 posts [100%]
Lawrenceville GA
Your idle valve terminals would be RSO and RSC. Rotary solenoid open and Rotary solenoid close. So it's a 3-wire idle valve. There will be a 12V wire to the valve, and the ECU pulses ground to both the open and close terminals. If it needs to open the valve it pulses RSO more and RSC less.
nyabinghi
165 posts [100%]
Ok good to know, so I think I will have no wiring to do at all and the install will be straight forward after the MS assembly.
Hope I will be able to begin the assembly next week.
Thanks
knucklesson
91 posts [100%]
Duluth GA
Russ
Do we connect the Spark 1 to IGt and Spark 2 to IGd? What happens to the multiplex igniters IGf signal?
On running the 3wire idle valve. Do you need a seperate board to convert the MS2 V3.57 Fidle output to RSO and RSC that the IACV needs?
Thanks
george
Russ
758 posts [100%]
Lawrenceville GA
 Re: Megasquirt DIYPNP and AE101 GZE (knucklesson) » Reply  Edit
What's up man?? It's been a minute since I've heard from you. How's everything?
Correct, IGT is ignition output 1 and IGD is ignition output 2. The MS won't use the IGF ignition confirmation signal.
To run a 3-wire from a 3.57 main board ECU you can either build this circuit
or you can ground the RSC wire of the valve through a high wattage resistor, something like a 50 watt 50 Ohm. This will give a constant closed pull on the valve and it would then operate like a 2-wire PWM valve.
knucklesson
91 posts [100%]
Duluth GA
Thanks Russ. I took some time away from the aw11. Can I drop the 3.57 off to you guys and have you build this circuit on a daugter board inside the case? I had a hard time with the idle control when I tried it with the resister grounding one leg closed.
george
Russ
758 posts [100%]
Lawrenceville GA
If I were me, I'd build this outside the ECU in a project box since the 3.57 doesn't have the proto expansion area like the 3.0 board. I am picturing something like a radio shack bread board to build the 3-wire idle circuit on, a project box enclosure, and whatever the best connector may be for the 5 wires. It should be pretty small, maybe a credit card sized box that's around 1/2 to 1 inch thick.
if you're free one day to pop up here for lunch or even just swing by the shop we can go chat about the best way to take care of your idle.
knucklesson
91 posts [100%]
Duluth GA
Thanks. I'm not good at soldering up circuits (not good is an understatement)...that's why I have a 3.57 right . How does you circuit compare to the glengarage board? http://www.glensgarage.com/3wi...c.pdf
Russ
758 posts [100%]
Lawrenceville GA
It's laid out a little different but they should work identical.
knucklesson
91 posts [100%]
Duluth GA
What dwell type would you use for the toyota multiplex?
nyabinghi
165 posts [100%]
Hi all,
I have assembled my DIYPNP and downloaded the latest extra firmware in the MS. To finish I have to connect the pins of the N76 connector to the connectors on the main board.
I listed all the connections to be made in the following spreadsheet. I'm not sure about where to connect FC on the MS and if I must use G1 or G2 for the second VR input (red row in the table). If someone can help me... thanks
https://docs.google.com/spread...=html
nyabinghi
165 posts [100%]
I just connected the following wire on the MS : E1, E01, E02, +B, +B1 and FPR according to this table https://docs.google.com/spread...=html
The ECU power on when I turn ignition ON, but the fuel pump doesn't work. I tried to turn on the fuel pump by using the output test mode feature in TunerStudio but the fuel pump still doesn't work.
At the moment FC is not connected at all so I think this is why the fuel pump doesn't turn on. According to the 4AGZE wiring diagram, it seems that if I connect FC to the fuel pump pin of the MS (and leave FPR wire disconnected) it should work. What do you think ?
Or May be I must connect FC to Power Ground (GND) and leave FPR connected to the fuel pump pin of the MS ?
On the following diagram (at the bottom), what is the use of the Fuel Pump Resitor ? Consider there is 12V at pin #3 of the fuel pump relay, it seems that the behavior is the following :
- If FPR is connected to ground the fuel pump is in serie with the resistor and then flow less
- If FPR is disconnected no resitor in serie with the fuel pump and the it flow much.
Right ?
Thanks
knucklesson
91 posts [100%]
Duluth GA
run ms fpr to fpr-1K fpr and ground fc-1F
nyabinghi
165 posts [100%]
OK thanks, will try that!
nyabinghi
165 posts [100%]
Quote, originally posted by knucklesson »
I tested that, thank you, it "works" but not the right way : the fuel pump turns ON as soon as the ignition is ON so I think this is not a good thing for the battery.
Will try to connect MS fuel pump to FC and let the Toyota FPR disconnected...
I wired TPS, IAT and CLT as in the spreadsheet, and this works perfect. Tomorrow I will try igniter, CAS and injectors.
Modified by nyabinghi at 7:57 AM 4/10/2012
nyabinghi
165 posts [100%]
Speardsheet updated https://docs.google.com/spread...=html :
- Connected FC to MS FUEL PUMP and leave FPR disconnected => works OK
- Tested the CAS using G2, G- and Ne => I get a constant 200rpm on the MS while cranking, OK
All other sensors are connected but not tested yet.
the galis
93 posts [100%]
Bridgetown Speedville
Hi I was looking over your pinout and realize that we have different pin outs I am also using an AE101 GZE with the DIYPNP mine isn't tested can help me or correct any of my mistakes
https://docs.google.com/spread...gid=0
nyabinghi
165 posts [100%]
 Re: Megasquirt DIYPNP and AE101 GZE (the galis) » Reply  Edit
Ok I can help you, no problem. But you have to give us access to your spreadsheet : publish it and post the URL of the published spreadsheet (File -> publish on the web)
 First  1 2 >  Last
» Return to Engine - 4A-GZE, and Supercharger/Turbocharger Projects
