 steering wheel splines?
Lildipper
92 posts [100%]
Independence MO
 steering wheel splines? Reply  Edit
i was wanting to get an aftermarket steering wheel and there arent a whole lot of choices for the aw11 so i was wondering if the splines on the aw11 are the same as the ae86 cuz that would make it a lot easier
1987 Toyota MR2 - project Lil Dipper
big port 4age - 20v individual throttle bodies w/ custom manifold, wiseco 10.5:1 comp. .020 bore pistons, crower billet rods, new balanced crank, cometic head gasket, head decked .020, 315cc injectors, EDIS ignition, arp head studs, main studs, and flywheel bolts, crower stage 2 cams, formula atlantic valves, hks valve springs, fidanza adjustable cam gears, shimmed oil pump, tvis delete and port, spec stage 2 clutch and lightweight flywheel, nst pulley kit, polyurathane motor mounts, d2 racing coilovers, megasquirt II
project status: getting tuned
Q-Authority
338 posts [100%]
San Diego CA
 Re: steering wheel splines? (Lildipper) » Reply  Edit
There are actually a lot of choices, depending upon how you look at it. You will need a hub adaptor for virtually any wheel you choose, and then can pick from a lot of wheels that will fit that hub adaptor. Many different manufacturers' wheels will even fit on other manufacturers' adaptors.
So long and thanks for all the fish! =)
Reggae Rules...
4374 posts [96%]
Wellington, NZ
Looks like it should... http://www.rhdjapan.com/boss-k...26441
Standard boss kits seem to have two sets of screw holes... one set suits Momo and
the other suits Nardi. And most other wheels seem to match one or the other.
jondee86 has been a member for 735,126 days.
