 Mr2 megasquirt
mikebass2112
16 posts [100%]
San Antonio Texas
 Mr2 megasquirt Reply  Edit
I have a 86 mr2 smallport swap and I have the megasquirt 1 version 2.2 and I can't get it to work. Any help? Any one have a diagram for a working jumper harness for it? My Mr2 is the pre trunk air cleaner.
volume4mouse
178 posts [100%]
your mom loves me
 Re: Mr2 megasquirt (mikebass2112) » Reply  Edit
I've had better luck on Mr2.com
Russ
758 posts [100%]
Lawrenceville GA
Can you give a little more info than "can't get it to work"? Does it power up? Does it just not start the car? Do any sensors react / respond?
Can you make as detailed a list as possible of what does work, what doesn't work, what may work but you're not sure, etc...?
Can you also describe your wiring / installation as detailed as possible?
What testing have you done, have you tested for power, tested for ground, tested for why it's not doing what it's not doing?
I can probably help you a bit faster if you shoot me an email to websales@diyautotune.com Just put something in the email about MR2 / 4AG / etc.. and I'll find it
