13133 posts [99%]
Portland
http://www.google.com/search?q...h=581might be a few links in here....
Information is POWER... learn the facts!! http://www.toyodiy.com/parts/ USE it! I've been wrong before... and at somepoint in time, I'll be wrong again
Davegt27
1305 posts [99%]
| Re: ae86 4age 16v trd ecu help (runfree) » | 6:00 PM 9/26/2011 |
Reply
Edit
they are for different motors photobucket resized the pics so they are almost useless
Davegt27 Code One Racing (C1R)
runfree
23 posts [100%]
dungarvan eire
| Re: ae86 4age 16v trd ecu help (Davegt27) » | 11:47 AM 9/27/2011 |
Reply
Edit
if only this was english haha but thank you very very much i wonder what does the small page say?? its way to small to see
Davegt27
1305 posts [99%]
| Re: ae86 4age 16v trd ecu help (runfree) » | 3:53 PM 9/27/2011 |
Reply
Edit
I don’t know I can’t find the book right now, but I never knew what it said anyway
Reggae Rules...
4374 posts [96%]
Wellington, NZ
| Re: ae86 4age 16v trd ecu help (runfree) » | 7:19 PM 9/27/2011 |
Reply
Edit
That TRD ECU usually came with the remote box for adjusting fuel and ignition settings. The ECU itself was designed for use with TRD Group A spec engines i.e. designed to work with a specific set of TRD hardware in the engine. There were settings to suit a range of TRD spec Toyota engines. Pretty old technology now. Should still work, but you can probably get more out of a modern ECU. And a modern ECU has fully adjustable fuel and ignition maps, whereas the TRD ECU only tweaks the base maps plus or minus across the board. Cheers... jondee86
jondee86 has been a member for 735,126 days.Give a person a fish, they eat for a day. Suggest they search before posting, and they learn a skill for a lifetime.
runfree
23 posts [100%]
dungarvan eire
| Re: ae86 4age 16v trd ecu help (jondee86) » | 9:44 AM 9/28/2011 |
Reply
Edit
ya i have the adjustable box and i know what each adjustable dial is for i was just wondering did anyone know what the switches on the inside were for,i got the ecu for handy enough cash so i said id purchase it,and its handy for running cams cos my oem ecu wont idle right with them but this one is idling good on them so far thanks for all your help
Reggae Rules...
4374 posts [96%]
Wellington, NZ
| Re: ae86 4age 16v trd ecu help (runfree) » | 11:19 AM 9/28/2011 |
Reply
Edit
I think the dip switches on the inside were for selecting what engine it was going to be installed on. I'll see if I have a note of it when I get home. Cheers... jondee86
Reggae Rules...
4374 posts [96%]
Wellington, NZ
| Re: ae86 4age 16v trd ecu help (jondee86) » | 11:28 PM 9/28/2011 |
Reply
Edit
Here ya go...| Quote » | | Please set the Dip Switch and Rotary Switch in compliance with the type of engine AE86 (4AGE) Dip1 = ON, Dip2 =OFF, Dip3 = OFF, Rotary Switch = 0 |
If you have an EP71 or EP71-T the settings are different, but since you have a 4AGE there is no point in listing them. Cheers... jondee86
Grant
3656 posts [86%]
San Jose ca
I saw one of these TRD ecu's on one of Taka Aono's cars. It looked pretty 90's tuner ish which I loved.
Stand Alone ECU tuning. Message me for details.Looking to buy a corolla manual rack and a TRD 3 gear transmission. *also wtb 4 point roll cage/bar for ae86 coupe
runfree
23 posts [100%]
dungarvan eire
thanks for all the info guys ,supose someone wouldnt know can i run 45mm trottle bodys on this ecu since i can adjust the timing and fueling???
ae101rulez
10 posts [100%]
Birmingham
Hi there, I purchased the exact similar ECU hoping to run it in a 2e turbo starlet. The ECU came straight from a 4age engine. Could I just plug it in and hope that magically it runs? Finger crossing
ae101rulez
10 posts [100%]
Birmingham
Hi Guys,this is the ecu I purchased.
parrot
1 posts [100%]
Melbourne Vic
| Re: ae86 4age 16v trd ecu help (Davegt27) » | 4:04 AM 2/20/2012 |
Reply
Edit
DaveGT27, I've PM'd you I think. Long time since I was active here and the forum has changed somewhat!My reading of the TRD Bible tells me I need 250cc injectors with this ECU. Does anyone know if they need to be high or low impedence?
KE15 Sprinter SL KE25 (to be 3TG TE27) AE86 4AGE GTV
